“The drone’s offboard mode is set to actuator=true.”,At the same time, the DDS topic has been correctly added and recognized,i try to run my code gazebo-classic"I found that when I was using thrust and torque for control, I set the thrust to [0, 0, -0.52] and torque = [0, 0, 0]. In the Gazebo simulation, after takeoff, the drone experiences a downward pitch, and after flying for a certain distance, the pitch suddenly increases dramatically until the drone flips. I would be very grateful if I could receive your help."
Related topics
Topic | Replies | Views | Activity | |
Offboard low-level control using thrust and torque setpoints | 1 | 318 | December 11, 2024 | |
Using thrust in setpoint_raw/attitude topic causes drone to crash | 8 | 1063 | June 18, 2019 | |
Controlling the actuators of quadcopter with torque and thrust inputs | 0 | 294 | November 14, 2023 | |
Torque, thrust scale | 3 | 689 | October 14, 2022 | |
Arm command causes takeoff in Gazebo | 1 | 398 | February 15, 2024 |
