Hi
I see from the Pixhawk 6X documentation that the IMU has a heater to maintain the temperature.
I assume this heater is controlled with a PWM signal.
Where can i find details of this port/pin as well as the heating element ?
Also what if you’re flying in a desert (With temperatures around 50 C).
(You could argue that you shouldn’t be flying in such heat )
Regards
Srinath
