A guide by a n00b for a n00b. Henceforth: RPi = Raspberry Pi
Click here.
DON’T CONNECT THE RED WIRE!
Seriously, I know you saw that wiring diagram with the red line between the Pixyhawk and the Raspberry Pi that’s being stealth edited out all over the place. Will it F your FMU? I dunno, sometimes grabbing that big capacitor doesn’t hurt by why take the chance? You’ll need a BEC to power the RPi.
..and here.
DON’T CONNECT Tx to Tx and/or Rx to Rx.
Did you see that other Pixyhawk/RPi post where they did that? I did ![]()
It’s bad. because reasons: https://elinux.org/RPi_Serial_Connection#H.2FW_considerations
Configuring the serial on the RPi
Install Raspbian via NOOBS
Most RPi’s have two UARTs (serial) which it uses and if you tell it not to it gives you the shitty one of the two. So. Go here,
ctrl-F" Disabling Linux’s use of console UART", and disable Linux’s use of console UART. If your RPi has bluetooth, murder it by editingconfig.txtwith$ sudo nano /boot/config.txtand add the line:dtoverlay=disable-btto the end of the file, then double murder it with$ sudo systemctl disable hciuart -
reboot
The serial port we are going to use is now:
/dev/serial0all otherttysare just imitating.
Make a connection.
- Aquire solder skillz
- Aquire wires and connectors.
- Make thing that connects the RPi
UARTtoTELEM 2on your flight controller.GND(Pin 6) toGNDTXD(Pin 8) toRXDRXD(Pin 10) toTXD
Install/build MAVSDK (This gonna suck)
We’re going to build this on the RPi if you know how to cross compile and have it work then wtf are you doing here?
Get the RPi ready for the pain:
$ sudo apt update$ sudo apt upgrade← Upgrade all the things$ sudo apt install python3-pip
Go here and Follow the ‘Building SDK from Source’ instructions for ‘Linux’. Step 5 will take a while so get a drink or four then finish with
cmake --build build/defaultthen drink some more. -
Install system-wide as described.
Now we’re going to build the “backend” that will be needed by MAVSDK-Python becasue you’re a n00b and as far as we’re concerned
c++isc+=1. If you follow the instructions the configuration(?) will fail and you’ll cry so do this instead:- Go to the MAVSDK directory.
$ sudo cmake -DBUILD_BACKEND=ON --symlink-install --cmake-args "-DCMAKE_SHARED_LINKER_FLAGS='-latomic'" "-DCMAKE_EXE_LINKER_FLAGS='-latomic'" -Bbuild/default -H.$ sudo cmake --build build/default- Take note, the file
mavsdk_serverthat you will need for MAVSDK-Python is in the totally obvious directory:MAVSDK/build/default/src/backend/src/
Install MAVSDK-Python
Grab a beer or three and go here. Scroll down to “Build and run from sources” and follow along from there. You might have an issue when you try
$ which protoc-gen-dcsdkand nothing shows up. In that case I used$ sudo find / -name protoc-gen-dcsdkto find the directory that containedprotoc-gen-dcsdk(in my case it was:/home/pi/.local/bin/) I then added that directory to $PATH with the command$ export PATH=$PATH:<path to protoc-gen-dcsdk>. After that I was all set. -
You tried
$ pip3 install mavsdk, didn’t you? -
Copy that
mavskd_serverfile intoMAVSDK-Python/mavsdk/bin/
Give it a whirl
Use that fancy connector to connect the RPi
UARTtoTELEM 2on your flight controller. -
In QGroundControl set
MAV_2_CONFIGtoTELEM 2and reboot the flight controller. (The baud rate is probably going to default to 921600 which you can check by looking atSER_TEL2_BAUDin QGroundControl) -
I assume you can SSH into your RPi at this point over WiFi and probably already have. If not, you should do that now. Then go to the
MAVSDK-Pythondirectory andcd examples/. From there we are going to edit an example with$ sudo nano firmware_version.pyand replace theawait drone.connect...line with:await drone.connect(system_address=“serial:///dev/serial0:921600”)
Now cross your fingers and type (while still in the
examplesdirectory)$ python3 firmware_version.py. If all went well you should see something like:Waiting for mavsdk_server to be ready…
Connected to mavsdk_server!
Waiting for drone to connect…
Drone discovered with UUID: 8670068434521822000
Version: [flight_sw_major: 1, flight_sw_minor: 10, flight_sw_patch: 0, flight_sw_vendor_major: 0, flight_sw_vendor_minor: 0, flight_sw_vendor_patch: 0, os_sw_major: 7, os_sw_minor: 29, os_sw_patch: 0]
If you just see it hang at Waiting for drone to connect... then a bad thing happed somewhere. Sorry bro.
Install MAVLINK Router (Optional)
Quick and dirty because Im tired:
- Clone this repo and
$ cd mavlink-router/ $ git submodule update --init --recursive$ sudo apt install python-future$ sudo apt install python3-future$ sudo apt install libtool$ sudo apt install autoconf$ sudo -s← root shell (yes rlly)# ./autogen.sh && ./configure CFLAGS='-g -O2' \ --sysconfdir=/etc --localstatedir=/var --libdir=/usr/lib \ --prefix=/usr# make# make install
Example
main.conffile:
[General]
#Mavlink-router serves on this TCP port
TcpServerPort=5790
ReportStats=false
MavlinkDialect=common
Log=/home/pi/logs/mavlink-router
DebugLogLevel=debug
[UartEndpoint alpha]
Device=/dev/serial0
Baud=921600,115200,57600
FlowControl=false
[UdpEndpoint bravo]
Mode=normal
Address=127.0.0.1
Port=14550
Goodnight you Princes of Maine, you Kings of New England!
Quirks (Part 1?):
The RPi Zero W uses armv6 and has issues with libatomic which is why I added the `-latomic’ flags for the MAVSDK build. For other RPi with armv7 + this might not be needed.
The RPi 3 A+ does not have enough memory to build MAVSDK which I didn’t realize until just now. If I have a free USB port on my RPi I usually put a low profile flash drive in and make it swap which solves memory issues and I suspect helps take load off the SD card. (https://askubuntu.com/questions/173676/how-to-make-a-usb-stick-swap-disk)
