Is there any plans to support the Kakute F7 mini v3?
It’s a really tiny and pratical flight controller, and a support would benefit the community.
Thanks,
M
Thanks,
M
What happens if you flash the normal kakuteF7 image?
Hi @j_p,
Thanks for the quick reply @j_p, I followed the steps in there:
https://docs.px4.io/master/en/advanced_config/bootloader_update_from_betaflight.html,
When I flash the bootloader, the board is stuck in DFU mode I believe, and I cannot see the USB in /dev/tty.usbModelXXX anymore.
I can push the button, connect to betaflight and reflash it again afterwards to unbricked the board
When I directly connect the board to qgroundcontrol after it’s flashed with betaflight:
It stays a couple of seconds in this mode:
And then show this:
Let me know if I can try something (if you do a branch on the bootloader code for instance, I can try it for you).
Cheers,
M
Have you tried DFuSe Demo?
It has a button to leave DFU mode.
Hi @jimdgit,
Nope I haven’t tried, but after I flash the bootloader for kakute f7 and cannot see the USB device anymore, do you think that with DFuSe demo I would be able to see the device and flash PX4?
thanks!
The v3 uses an f722 processor, which is not supported (insufficient flash). The v2 uses an f745, which is.
