I am using MAVSDK/Python to start the offboard mode in flight after the drone has arrived at some destination point.
When activating offboard mode, the drone makes a strong movement a couple of meters sidewards and down, like if its trying to correct its position.
I set a first setpoint before I enable offboard mode:
myPosition=PositionNedYaw(0.00, 0.00, alt, yaw)
with alt and yaw being the current altitude and yaw as set in the
drone.action.goto_location() command before.
then call
await drone.offboard.set_position_ned(myPosition)
this is where the drone moves at full pace a couple of meters sidewards and down. From there on, I can make regular offboard moves with no problems.
All works fine in the simulator.
Thanks for advice…
