Serial com not working with px4 1.14 and cube orange plus
Here’s an improved version of your message:
Hello everyone,
I’m currently facing challenges with setting up serial communication in PX4 through a custom task module. My goal right now is simply to send the number “three” over serial. I have a Cube Orange Plus connected via the TELEM2 port (ttyS1) to an FTDI USB adapter, which in turn connects to MATLAB, where I’m monitoring the serial data. Although PX4 indicates a successful write operation, MATLAB isn’t receiving any data.
I Have tried setting it up as closely to a serial driver as possible but it still doesn’t want to write though the port. I was getting errors with the buffer being too full before so now when it stops writing I clear the buffer.
I’ve attached my files below, which outline the code for the custom serial communication. Has anyone encountered a similar issue, or is there something additional I might need to configure in PX4 to get this working?
Any guidance would be greatly appreciated—thank you in advance!
Output from nsh terminal
INFO  [strat_serial_task] we wrote something
INFO  [strat_serial_task] write error Try again
ERROR [strat_serial_task] Failed to get Tx buffer status, number of iterations: 375
ERROR [strat_serial_task] Tx buffer check error: Not a typewriter
CMakeLists.txt
set(MODULE_NAME strat_serial_task)
Add definitions specific to PX4
add_definitions(
    -DNUMST=1
    -DNCSTATES=0
    -DHAVESTDIO
    -DMODEL_HAS_DYNAMICALLY_LOADED_SFCNS=0
    -DCLASSIC_INTERFACE=0
    -DALLOCATIONFCN=0
    -DTID01EQ=0
    -DTERMFCN=1
    -DONESTEPFCN=1
    -DMAT_FILE=0
    -DMULTI_INSTANCE_CODE=0
    -DINTEGER_CODE=0
    -DMT=0
    -DPX4
    -DNULL=0
    -DMW_PX4_NUTTX_BUILD
    -DEXTMODE_DISABLETESTING
    -DEXTMODE_DISABLEPRINTF
    -DEXTMODE_DISABLE_ARGS_PROCESSING=1
    -D__linux__
px4_add_module(
	MODULE modules__strat_serial_task
	MAIN strat_serial_task
    COMPILE_FLAGS
	SRCS
		SCI_ST.hpp
		SCI_ST.cpp
		strat_st.cpp
		strat_st.hpp
	MODULE_CONFIG
		module.yaml
	COMPILE_FLAGS
		-fpermissive
		-Wno-narrowing
		-Wno-address-of-packed-member
		-Wno-cast-align
	INCLUDES
		${PX4_SOURCE_DIR}/src/modules/${MODULE_NAME}
Remove -Werror from compile options
get_target_property(MODULE_COMPILE_FLAGS modules__${MODULE_NAME} COMPILE_OPTIONS)
list(REMOVE_ITEM MODULE_COMPILE_FLAGS -Werror)
set_target_properties(modules__${MODULE_NAME} PROPERTIES COMPILE_OPTIONS "${MODULE_COMPILE_FLAGS}")
module.yaml
module_name: Strat Serial
serial_config:
    - command: strat_serial_task start -d ${SERIAL_DEV}
      port_config_param:
        group: Communication
SCI_ST.cpp
#include "SCI_ST.hpp"
#include <stdio.h>   /* Standard input/output definitions */
#include <string.h>  /* String function definitions */
#include <unistd.h>  /* UNIX standard function definitions */
#include <fcntl.h>   /* File control definitions */
#include <errno.h>   /* Error number definitions */
#include <termios.h> /* POSIX terminal control definitions */
#include <stdbool.h>
// time-out using select( )
#include <sys/types.h>
#include <sys/stat.h>
#include <sys/select.h>
#include <sys/ioctl.h>
#include <sys/time.h>
/* Local defines */
#define NUM_MAX_SCI_DEV (10) /*a random choice - no limit on serial devices*/
#define MAX_DEV_NAME (64)
#define MICROS 1000000L
#define NANOS 1000000000L
#define DEBUG 0
static SCI_dev_t sciDev[NUM_MAX_SCI_DEV];
static uint32_T AllBaudrates[] = {50,     75,      110,     134,     150,     200,     300,
                                  600,    1200,    1800,    2400,    4800,    9600,    19200,
                                  38400,  57600,   115200,  230400,  460800,  500000,  576000,
                                  921600, 1000000, 1152000, 1500000, 2000000, 2500000, 3000000};
/* Open SERIAL channel*/
static int SERIAL_open(const char* port) {
    int fd;
    int retries = 0;
    /* O_NDELAY: disregard DCD signal line state
     * O_NOCTTY: we don't want to be the controlling terminal */
    fflush(stdout);
    while (retries < 15) {
        fd = open(port, O_RDWR | O_NOCTTY | O_NONBLOCK);
        if (fd != -1) {
            break;
        // sleep a bit and retry. There seems to be a NuttX bug
        // that can cause ttyACM0 to not be available immediately,
        // but a small delay can fix it
        usleep(50000);
        retries++;
    if (fd == -1) {
        perror("SERIAL_open/open");
    /*flush both data received but not read, and data written but not transmitted.*/
    tcflush(fd, TCIOFLUSH);
    return fd;
/* Return device ID given serial port name */
int getCurrSciDev(const char* name) {
    int i;
    for (i = NUM_MAX_SCI_DEV - 1; i > -1; i--) {
        if ((name != NULL) && (sciDev[i].portname != NULL) &&
            (strncmp(name, sciDev[i].portname, MAX_DEV_NAME) == 0)) {
            break;
    return i;
/* Allocate device*/
int Serial_alloc(const char* name) {
    int i;
    for (i = 0; i < NUM_MAX_SCI_DEV; i++) {
        if (sciDev[i].portname == NULL) {
            break;
    if (i >= NUM_MAX_SCI_DEV) {
        fprintf(stderr, "Cannot allocate a new device for %s: [%d]\n", name, i);
        return -1;
    sciDev[i].portname = strndup(name, MAX_DEV_NAME);
    return i;
MW_Handle_Type MW_SCI_Open(void* SCIModule,
                           uint8_T isString,
                           uint32_T RxPin, /* Not used */
                           uint32_T TxPin) /*Not Used*/
    MW_Handle_Type SCIHandle = (MW_Handle_Type)NULL;
    char* port;
    int currSciDev;
    /* Check parameters */
    if (0 == isString) {
        fprintf(stderr, "Only string as SCI Module name is supported.\n");
        exit(-1);
    } else {
        /* Initialize the SCI Module*/
        port = (char*)SCIModule;
#ifdef PX4_CONNECTEDIO
        /* For IO, the port name will be sent from host PC. IO wrapper does not use the length of
         * port name and pass it as the last part in the packet. While reading port name in target,
         * everything remaining in the buffer is read as port name. Because of this, sometimes extra
         * junk bytes get added to the port name. Since all the supported serial ports are of length
         * 10 (eg: /dev/ttyS1,/dev/ttyS6) manually ending the port name after 10 characters. note:
         * /dev/ttyACM0 is not supported for serial blocks as it is conflicting with Connected I/O.
        port[10] = '\0';
#endif
#if DEBUG
        printf("In MW_SCI_Open. Port = %s\n", port);
#endif
        currSciDev = getCurrSciDev(port);
        fprintf(stdout, "INIT: sciDevNo = %d\n", currSciDev);
        if (currSciDev == -1) {
            currSciDev = Serial_alloc(port);
            fprintf(stdout, "ALLOC: devNo = %d\n", currSciDev);
                fprintf(stderr, "Error opening Serial bus (SERIAL_init/Alloc).\n");
                exit(-1);
        if (sciDev[currSciDev].fd < 0) {
            sciDev[currSciDev].fd = SERIAL_open(port);
                fprintf(stderr, "Error opening Serial bus (SERIAL_init/Open).\n");
                exit(-1);
        SCIHandle = (MW_Handle_Type)&sciDev[currSciDev];
    return SCIHandle;
/* Set SCI frame format */
MW_SCI_Status_Type MW_SCI_SetFrameFormat(MW_Handle_Type SCIModuleHandle,
                                         uint8_T DataBitsLength,
                                         MW_SCI_Parity_Type Parity,
                                         MW_SCI_StopBits_Type StopBits) {
    SCI_dev_t* sci;
    struct termios options;
    if (NULL != (void*)SCIModuleHandle) {
        sci = (SCI_dev_t*)SCIModuleHandle;
        if (tcgetattr(sci->fd, &options) < 0) {
            perror("SERIAL_GetAttribute");
            return MW_SCI_BUS_ERROR;
        /* Set data bits*/
        options.c_cflag &= ~CSIZE;
        switch (DataBitsLength) {
        case 5:
            options.c_cflag |= CS5;
            break;
        case 6:
            options.c_cflag |= CS6;
            break;
        case 7:
            options.c_cflag |= CS7;
            break;
        case 8:
            options.c_cflag |= CS8;
            break;
        default:
            perror("SERIAL_SetFrameFormat/DataBitsLength");
#ifndef PX4_CONNECTEDIO
        if (strcmp(sci->portname, "/dev/ttyACM0") == 0) {
            Parity = static_cast<MW_SCI_Parity_Type>(MW_TTYACM0_PARITY);
            StopBits = static_cast<MW_SCI_StopBits_Type>((2 * MW_TTYACM0_STOPBIT) + 1);
        } else if (strcmp(sci->portname, "/dev/ttyS0") == 0) {
            Parity = static_cast<MW_SCI_Parity_Type>(MW_TTYS0_PARITY);
            StopBits = static_cast<MW_SCI_StopBits_Type>((2 * MW_TTYS0_STOPBIT) + 1);
        } else if (strcmp(sci->portname, "/dev/ttyS1") == 0) {
            Parity = static_cast<MW_SCI_Parity_Type>(MW_TTYS1_PARITY);
            StopBits = static_cast<MW_SCI_StopBits_Type>((2 * MW_TTYS1_STOPBIT) + 1);
        } else if (strcmp(sci->portname, "/dev/ttyS2") == 0) {
            Parity = static_cast<MW_SCI_Parity_Type>(MW_TTYS2_PARITY);
            StopBits = static_cast<MW_SCI_StopBits_Type>((2 * MW_TTYS2_STOPBIT) + 1);
        } else if (strcmp(sci->portname, "/dev/ttyS3") == 0) {
            Parity = static_cast<MW_SCI_Parity_Type>(MW_TTYS3_PARITY);
            StopBits = static_cast<MW_SCI_StopBits_Type>((2 * MW_TTYS3_STOPBIT) + 1);
        } else if (strcmp(sci->portname, "/dev/ttyS4") == 0) {
            Parity = static_cast<MW_SCI_Parity_Type>(MW_TTYS4_PARITY);
            StopBits = static_cast<MW_SCI_StopBits_Type>((2 * MW_TTYS4_STOPBIT) + 1);
        } else if (strcmp(sci->portname, "/dev/ttyS5") == 0) {
            Parity = static_cast<MW_SCI_Parity_Type>(MW_TTYS5_PARITY);
            StopBits = static_cast<MW_SCI_StopBits_Type>((2 * MW_TTYS5_STOPBIT) + 1);
        } else if (strcmp(sci->portname, "/dev/ttyS6") == 0) {
            Parity = static_cast<MW_SCI_Parity_Type>(MW_TTYS6_PARITY);
            StopBits = static_cast<MW_SCI_StopBits_Type>((2 * MW_TTYS6_STOPBIT) + 1);
        } else {
            perror("SERIAL_SetFrameFormat/Parity");
#endif
        /* Set parity*/
        switch (Parity) {
        case MW_SCI_PARITY_NONE:
            options.c_cflag &= ~PARENB;
            break;
        case MW_SCI_PARITY_EVEN:
            options.c_cflag |= PARENB;
            options.c_cflag &= ~PARODD;
            break;
        case MW_SCI_PARITY_ODD:
            options.c_cflag |= PARODD;
            break;
        default:
        /* Set stop bits (1 or 2)*/
        switch (StopBits) {
        case MW_SCI_STOPBITS_1:
            options.c_cflag &= ~CSTOPB;
            break;
        case MW_SCI_STOPBITS_2:
            options.c_cflag |= CSTOPB;
            break;
        default:
            perror("SERIAL_SetFrameFormat/StopBits");
        /* Set attributes*/
        if (tcsetattr(sci->fd, TCSANOW, &options) < 0) {
            perror("SERIAL_SetAttribute");
        tcflush(sci->fd, TCIOFLUSH);
    return MW_SCI_SUCCESS;
/* Set the SCI bus speed */
MW_SCI_Status_Type MW_SCI_SetBaudrate(MW_Handle_Type SCIModuleHandle, uint32_T Baudrate) {
    SCI_dev_t* sci;
    speed_t optBaud;
// #ifndef PX4_CONNECTEDIO
//         if (strcmp(sci->portname, "/dev/ttyACM0") == 0) {
//             Baudrate = AllBaudrates[MW_TTYACM0_BAUDRATE];
//         } else if (strcmp(sci->portname, "/dev/ttyS0") == 0) {
//             Baudrate = AllBaudrates[MW_TTYS0_BAUDRATE];
//         } else if (strcmp(sci->portname, "/dev/ttyS1") == 0) {
//             Baudrate = AllBaudrates[MW_TTYS1_BAUDRATE];
//         } else if (strcmp(sci->portname, "/dev/ttyS2") == 0) {
//             Baudrate = AllBaudrates[MW_TTYS2_BAUDRATE];
//         } else if (strcmp(sci->portname, "/dev/ttyS3") == 0) {
//             Baudrate = AllBaudrates[MW_TTYS3_BAUDRATE];
//         } else if (strcmp(sci->portname, "/dev/ttyS4") == 0) {
//             Baudrate = AllBaudrates[MW_TTYS4_BAUDRATE];
//         } else if (strcmp(sci->portname, "/dev/ttyS5") == 0) {
//             Baudrate = AllBaudrates[MW_TTYS5_BAUDRATE];
//         } else if (strcmp(sci->portname, "/dev/ttyS6") == 0) {
//             Baudrate = AllBaudrates[MW_TTYS6_BAUDRATE];
//         } else if (strcmp(sci->portname, "/dev/ttyS7") == 0) {
//             Baudrate = AllBaudrates[MW_TTYS7_BAUDRATE];
//         } else {
//             perror("SERIAL_SetBaudrate");
//             return MW_SCI_BUS_ERROR;
// #endif
        /* Set parameters of the serial connection*/
        //         optBaud = Baudrate;
        switch (Baudrate) {
        case 50:
            optBaud = B50;
            break;
        case 75:
            optBaud = B75;
            break;
        case 110:
            optBaud = B110;
            break;
        case 134:
            optBaud = B134;
            break;
        case 150:
            optBaud = B150;
            break;
        case 200:
            optBaud = B200;
            break;
        case 300:
            optBaud = B300;
            break;
        case 600:
            optBaud = B600;
            break;
        case 1200:
            optBaud = B1200;
            break;
        case 1800:
            optBaud = B1800;
            break;
        case 2400:
            optBaud = B2400;
            break;
        case 4800:
            optBaud = B4800;
            break;
        case 9600:
            optBaud = B9600;
            break;
        case 19200:
            optBaud = B19200;
            break;
        case 38400:
            optBaud = B38400;
            break;
        case 57600:
            optBaud = B57600;
            break;
        case 115200:
            optBaud = B115200;
            break;
        case 230400:
            optBaud = B230400;
            break;
        case 460800:
            optBaud = B460800;
            break;
        case 500000:
            optBaud = B500000;
            break;
        case 576000:
            optBaud = B576000;
            break;
        case 921600:
            optBaud = B921600;
            break;
        case 1000000:
            optBaud = B1000000;
            break;
        case 1152000:
            optBaud = B1152000;
            break;
        case 1500000:
            optBaud = B1500000;
            break;
        case 2000000:
            optBaud = B2000000;
            break;
        case 2500000:
            optBaud = B2500000;
            break;
        case 3000000:
            optBaud = B3000000;
            break;
        default:
        /* Enable the receiver and set local mode*/
        options.c_cflag |= (CLOCAL    /*To not become port 'owner'*/
                            | CREAD); /*Allow reading of incoming data*/
        options.c_iflag &= ~(IXON     /*Disable Software Flow Control*/
                             | IXOFF | IXANY);
        options.c_lflag &= ~(ICANON   /*To have raw output*/
                             | ECHO   /*Disable input character echo*/
                             | ECHOE  /*Disable echo character erase*/
                             | ISIG); /*Disable SIGINTR, SIGSUSP, SIGDSUSP,
                                       * and SIGQUIT signals*/
        /* Set character read options*/
        options.c_cc[VMIN] = 0;
        options.c_cc[VTIME] = 0; /*This is a completely non-blocking read -*/
        /* Local options. Configure for RAW input*/
        options.c_oflag &= ~OPOST; /*Disable Post processing of output*/
        /* Set baud rate*/
        if (cfsetispeed(&options, optBaud) < 0) {
            PX4_INFO("SERIAL_Set_ip_Speed");
        if (cfsetospeed(&options, optBaud) < 0) {
            perror("SERIAL_Set_op_Speed");
        /* Set attributes*/
        } else {
            printf("Serial Port Opened. fd = %d. BaudRate = %lu\n", sci->fd, optBaud);
    struct termios current_options;
    if (tcgetattr(sci->fd, &current_options) == 0) {
        speed_t actual_baud = cfgetispeed(&current_options);
        PX4_INFO("Current baud rate for /dev/ttyS1 is: %lu", (unsigned long)actual_baud);
    } else {
        PX4_ERR("Failed to get baud rate for /dev/ttyS1");
MW_SCI_Status_Type MW_SCI_ConfigureHardwareFlowControl(
    MW_SCI_HardwareFlowControl_Type HardwareFlowControl,
    uint32_T RtsDtrPin,
    uint32_T CtsDtsPin) {
    uint8_T hardwareFCEnable = 0;
    SCI_dev_t* sci;
            hardwareFCEnable = MW_TTYACM0HWFLOWCONTROL_CHECKBOX;
            hardwareFCEnable = MW_TTYS0HWFLOWCONTROL_CHECKBOX;
            hardwareFCEnable = MW_TTYS1HWFLOWCONTROL_CHECKBOX;
            hardwareFCEnable = MW_TTYS2HWFLOWCONTROL_CHECKBOX;
            hardwareFCEnable = MW_TTYS3HWFLOWCONTROL_CHECKBOX;
            hardwareFCEnable = MW_TTYS4HWFLOWCONTROL_CHECKBOX;
            hardwareFCEnable = MW_TTYS5HWFLOWCONTROL_CHECKBOX;
            hardwareFCEnable = MW_TTYS6HWFLOWCONTROL_CHECKBOX;
        } else {
#endif
        /* Set data bits for Hardware Flow Control*/
        if (1 == hardwareFCEnable) {
            options.c_cflag |= CRTSCTS;
        } else if (0 == hardwareFCEnable) {
            options.c_cflag &= ~CRTSCTS;
/* Transmit the data over SCI */
MW_SCI_Status_Type MW_SCI_Transmit(MW_Handle_Type SCIModuleHandle,
                                   uint8_T* TxDataPtr,
                                   uint32_T TxDataLength) {
    SCI_dev_t* sci;
    int ret;
        int currSciDev;
        currSciDev = getCurrSciDev(sci->portname);
        PX4_INFO("Inside Transmit. SCIModule = %d. | ", currSciDev);
        PX4_INFO("port name = %s | fd = %d | ", sci->portname, sci->fd);
        PX4_INFO("data : ");
        uint32_T i;
        for (i = 0; i < TxDataLength; i++) {
            PX4_INFO("[%d]", TxDataPtr[i]);
        PX4_INFO("\n");
        // FAR struct file *filep;
        // ssize_t ret_test;
        // ret_test = (ssize_t)fs_getfilep(sci->fd, &filep);
        // PX4_INFO("%p", filep->f_inode);
        if (0 == sci->busy) {
            sci->busy = 2; /* Set the busy flag */
            ret = write(sci->fd, TxDataPtr, TxDataLength);
            if (ret < 0) {
                PX4_ERR("SERIAL_write/write: %s", strerror(errno)); /* Log the exact error */
                sci->busy = 0; /* Reset the busy flag */
        } else {
            PX4_ERR("Serial Port busy. Unable to perform write operation.");
            return MW_SCI_TX_BUSY;
        if (ret < 0) {
            PX4_ERR("SERIAL_write/write");
/* Close SERIAL channel*/
static void SERIAL_close(int fd) {
    int ret;
    ret = close(fd);
    if (ret < 0) {
        /* EBADF, EINTR, EIO: In all cases, descriptor is torn down*/
        perror("SERIAL_close/close");
/* Release SCI module */
void MW_SCI_Close(MW_Handle_Type SCIModuleHandle) {
    SCI_dev_t* sci;
        if (sci->fd > 0) {
#if DEBUG
            printf("Inside SCI_Close. port name = %s | fd = %d \n", sci->portname, sci->fd);
#endif
            SERIAL_close(sci->fd);
            sci->fd = -1;
strat_st.cpp file
 *   Copyright (c) 2018 PX4 Development Team. All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * 1. Redistributions of source code must retain the above copyright
 *    notice, this list of conditions and the following disclaimer.
 * 2. Redistributions in binary form must reproduce the above copyright
 *    notice, this list of conditions and the following disclaimer in
 *    the documentation and/or other materials provided with the
 *    distribution.
 * 3. Neither the name PX4 nor the names of its contributors may be
 *    used to endorse or promote products derived from this software
 *    without specific prior written permission.
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
 * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
 * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
 * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
 * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
 * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
 * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
 * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
 * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
 * ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
 * POSSIBILITY OF SUCH DAMAGE.
#include "strat_st.hpp"
#include <px4_platform_common/getopt.h>
#include <px4_platform_common/log.h>
#include <px4_platform_common/posix.h>
#include <uORB/topics/parameter_update.h>
#include <uORB/topics/sensor_combined.h>
StratSerialTask::StratSerialTask()
	: ModuleParams(nullptr)
int StratSerialTask::print_status()
	PX4_INFO("Running");
	// TODO: print additional runtime information about the state of the module
	return 0;
int StratSerialTask::custom_command(int argc, char *argv[])
	if (!is_running()) {
		print_usage("not running");
		return 1;
	// additional custom commands can be handled like this:
	if (!strcmp(argv[0], "do-something")) {
		get_instance()->do_something();
		return 0;
	return print_usage("unknown command");
int StratSerialTask::task_spawn(int argc, char *argv[])
	_task_id = px4_task_spawn_cmd("strat_serial_task",
				      SCHED_DEFAULT,
				      SCHED_PRIORITY_DEFAULT,
				      1024,
				      (px4_main_t)&run_trampoline,
				      (char *const *)argv);
	if (_task_id < 0) {
		_task_id = -1;
		return -errno;
	return 0;
StratSerialTask *StratSerialTask::instantiate(int argc, char *argv[])
	// int example_param = 0;
	// bool example_flag = false;
	//bool error_flag = false;
	//int myoptind = 1;
	//int ch;
	//const char *myoptarg = nullptr;
	// // parse CLI arguments
	// while ((ch = px4_getopt(argc, argv, "p:f", &myoptind, &myoptarg)) != EOF) {
	// 	switch (ch) {
	// 	// case 'p':
	// 	// 	example_param = (int)strtol(myoptarg, nullptr, 10);
	// 	// 	break;
	// 	// case 'f':
	// 	// 	example_flag = true;
	// 	// 	break;
	// 	case '?':
	// 		error_flag = true;
	// 		PX4_ERR("Error flag set true");
	// 		break;
	// 	default:
	// 		PX4_WARN("unrecognized flag");
	// 		break;
	// if (error_flag) {
	// 	return nullptr;
	StratSerialTask *instance = new StratSerialTask();
	if (instance == nullptr) {
		PX4_ERR("alloc failed");
	if(!instance->start_serial(57600)){
		PX4_ERR("Serial failed to start");
		return nullptr;
	return instance;
bool StratSerialTask::start_serial(int baud)
	PX4_INFO("Initializing StratSerialTask...");
	static const char* serial_device = "/dev/ttyS1";
	void* SCIModuleVoidPtr = (void*)serial_device;
	serial_handle = MW_SCI_Open(SCIModuleVoidPtr, true, MW_UNDEFINED_VALUE, MW_UNDEFINED_VALUE);
	if (serial_handle == nullptr) {
		PX4_ERR("Failed to open serial port.");
		return false;
	}else{
		PX4_INFO("Serial port open %p", serial_handle);
	// Set the baud rate, frame format, and hardware flow control
	if(MW_SCI_SetBaudrate(serial_handle, 57600) == 0){
		PX4_INFO("Baudrate set");
	}else{
		PX4_ERR("Baudrate NOT set");
		return false;
	if(MW_SCI_SetFrameFormat(serial_handle, 8, MW_SCI_PARITY_NONE, MW_SCI_STOPBITS_1) == 0){
		PX4_INFO("Frame format set");
	}else{
		PX4_ERR("Frame format NOT set");
		return false;
	if( MW_SCI_ConfigureHardwareFlowControl(serial_handle, MW_SCI_FLOWCONTROL_NONE, MW_UNDEFINED_VALUE, MW_UNDEFINED_VALUE) == 0){
		PX4_INFO("Flow control set");
	}else{
		PX4_ERR("Flow control NOT set");
		return false;
	sci = (SCI_dev_t*)serial_handle;
	PX4_INFO("%d", sci->fd);
	return true;
void StratSerialTask::run()
	// Example: run the loop synchronized to the sensor_combined topic publication
	int sensor_combined_sub = orb_subscribe(ORB_ID(sensor_combined));
	px4_pollfd_struct_t fds[1];
	fds[0].fd = sensor_combined_sub;
	fds[0].events = POLLIN;
	// initialize parameters
	parameters_update(true);
	usleep(20000000);
	int tx_buffer_available;
	int count = 0;
	while (!should_exit()) {
		usleep(100000);
		// wait for up to 1000ms for data
		int pret = px4_poll(fds, (sizeof(fds) / sizeof(fds[0])), 1000);
		if (pret == 0) {
			// Timeout: let the loop run anyway, don't do `continue` here
		} else if (pret < 0) {
			// this is undesirable but not much we can do
			PX4_ERR("poll error %d, %d", pret, errno);
			px4_usleep(50000);
			continue;
		} else if (fds[0].events & POLLIN) {
			struct sensor_combined_s sensor_combined;
			orb_copy(ORB_ID(sensor_combined), sensor_combined_sub, &sensor_combined);
			//TODO: do something with the data...
			//uint8_t number_to_send = 42;  // Your number
			//int bytes_written = dprintf(sci->fd, "%d\n", number_to_send);
			uint8_t integer_value[8] = {3};
			uint8_t data_to_send[sizeof(integer_value)/sizeof(uint8_t)];
			memcpy(data_to_send, &integer_value, sizeof(integer_value)/sizeof(uint8_t));
			ssize_t write_size = write(sci->fd, &data_to_send, sizeof(data_to_send));
			if (write_size>0){
				PX4_INFO("we wrote something");
				count++;
			}else{
				PX4_INFO("write error %s",strerror(errno));
							// Flush the Tx bufferif
				if(ioctl(sci->fd, TCFLSH, TCOFLUSH) < 0) {
					PX4_ERR("Failed to flush Tx buffer");
					//return;
				if (ioctl(sci->fd, TIOCOUTQ, &tx_buffer_available) < 0) {
					PX4_ERR("Failed to get Tx buffer status, number of iterations: %d", count);
					//close(fd);
					PX4_ERR("Tx buffer check error: %s",strerror(errno));
			// PX4_INFO("byte %d",data_to_send[0]);
			// if (bytes_written > 0) {
			// 	PX4_INFO("Message successfully sent: %d bytes", bytes_written);
			// } else {
			// 	PX4_ERR("Failed to send message over serial");
	PX4_INFO("module exited");
	parameters_update();
	MW_SCI_Close(serial_handle);
	orb_unsubscribe(sensor_combined_sub);
void StratSerialTask::parameters_update(bool force)
	// check for parameter updates
	if (_parameter_update_sub.updated() || force) {
		// clear update
		parameter_update_s update;
		_parameter_update_sub.copy(&update);
		// update parameters from storage
		updateParams();
int StratSerialTask::print_usage(const char *reason)
	if (reason) {
		PX4_WARN("%s\n", reason);
	PRINT_MODULE_DESCRIPTION(
		R"DESCR_STR(
### Description
Section that describes the provided module functionality.
This is a template for a module running as a task in the background with start/stop/status functionality.
### Implementation
Section describing the high-level implementation of this module.
### Examples
CLI usage example:
$ module start -f -p 42
)DESCR_STR");
	PRINT_MODULE_USAGE_NAME("strat_serial_task","module");
	PRINT_MODULE_USAGE_COMMAND("start");
	// PRINT_MODULE_USAGE_PARAM_FLAG('f', "Optional example flag", true);
	// PRINT_MODULE_USAGE_PARAM_INT('p', 0, 0, 1000, "Optional example parameter", true);
	PRINT_MODULE_USAGE_DEFAULT_COMMANDS();
	return 0;
int strat_serial_task_main(int argc, char *argv[])
	return StratSerialTask::main(argc, argv);
