When a mission is saved from mission creation mode, it appears that zoom level is not saved. When QGroundControl is restarted later and the mission reloaded, the zoom level is back to the entire world, necessitating zooming all the way back down to the neighborhood level again. Every time! Is there some way to save the zoom level with missions, or at least specify that whenever QGroundControl is started, it should use by default a zoom level other than the entire planet? Thanks.
Are you using the latest version of QGC? Stable 3.4.3 or a recent daily build?
3.4.0 Linux stable build – which I installed quite recently.
Looks like zooming is buggy. It should zoom in to show the mission when you load the mission. Can you enter an issue with exact step by step details to reproduce including the Plan file.
