Rotor count limit for gz_sim of VTOLS?
I am trying to build a gazebo (new, not classic) simulator for an octorotor vtol vehicle. However, it seems that there is a hard limit on the amount of total ESCs to 8, even though the total number of supported motors goes up to 12. The sim_gz parameter only goes up to a total count of 8, so I can’t add my aircraft’s pusher motor. When I try, I get the following error:
[Err] [MulticopterMotorModel.cc:528] You tried to access index 8 of the Actuator velocity array which is of size 8
Does anyone have a suggested workaround for this? Is it just not possible to build an octorotor VTOL simulator in gazebo at the moment?
Thanks
Hi @bloodbornekart , could you share the gz VTOL octorotor model that you are trying to build and the associated PX4 airframe file please?
Hi Benja, thank you for your reply. I will send the files as soon as I can. However, I think that the problem isn’t in the SDF file because the motors are laid out properly into 8 seperate motor plugins (I tried grouping them into pairs to make it behave as a quadrotor, and it works fine). The airframe I am using is just the standard VTOL airframe file but with the motor number increased to 9.
The issue I am running into seems to be that the esc count parameter only goes up to 8, so I can’t add the pusher prop. It’s also seen in the QGroundControl actuator UI, where it will show 9 motors but only 8 available ESCs for assignment.
Did you solve the issue? Because I have the same one but with 8 motors for lift and 2 for cruise :smiley:
Thanks for your help!
请问你解决这个问题了吗?我也遇到了,我现在在尝试搭建一个12轴的无人机
I have a PR that solves this: GZ: Update GZMixingInterfaceESC to support more than 8 ESCs by Baardrw · Pull Request #25081 · PX4/PX4-Autopilot · GitHub
The issue was that the GZBridge ESC interface behaves like a Dshot interface which only supports 8 ESCs.
