I have followed the toolchain installation process given for ubuntu 18.04 in Ubuntu Development Environment | PX4 User Guide, however when I try to
make px4_sitl gazebo
I am facing the following error :
FAILED: etc/init.d/rc.serial etc/init.d/rc.autostart etc/init.d/rc.autostart.post ROMFS/romfs_copy.stamp
I had to install gazebo 9 and a couple of modules as it had not been installed by the ubuntu.sh script in Tools/setup, and I am using the main branch of the px4-autopilot repo.
Here is my terminal output after I execute the make px4-sitl gazebo command :
[0/873] git submodule src/drivers/gps/devices
[2/873] ROMFS: copying, generating airframes
cd /home/barracuda/pix/PX4-Autopilot/build/px4_sitl_default/etc && /usr/bin/cmake -E remove_directory /home/barracuda/pix/PX4-Autopilot/build/px4_sitl_default/etc/* && /usr/bin/cmake -E tar xf /home/barracuda/pix/PX4-Autopilot/build/px4_sitl_default/romfs_files.tar && /usr/bin/python3 /home/barracuda/pix/PX4-Autopilot/Tools/px_process_airframes.py --airframes-path /home/barracuda/pix/PX4-Autopilot/build/px4_sitl_default/etc/init.d --start-script /home/barracuda/pix/PX4-Autopilot/build/px4_sitl_default/etc/init.d/rc.autostart --board px4_sitl && /usr/bin/python3 /home/barracuda/pix/PX4-Autopilot/Tools/serial/generate_config.py --rc-dir /home/barracuda/pix/PX4-Autopilot/build/px4_sitl_default/etc/init.d --serial-ports --ethernet --config-files /home/barracuda/pix/PX4-Autopilot/src/lib/battery/module.yaml /home/barracuda/pix/PX4-Autopilot/src/drivers/gps/module.yaml /home/barracuda/pix/PX4-Autopilot/src/drivers/osd/msp_osd/module.yaml /home/barracuda/pix/PX4-Autopilot/src/modules/control_allocator/module.yaml /home/barracuda/pix/PX4-Autopilot/src/modules/mavlink/module.yaml /home/barracuda/pix/PX4-Autopilot/src/modules/payload_deliverer/module.yaml /home/barracuda/pix/PX4-Autopilot/src/modules/sensors/module.yaml /home/barracuda/pix/PX4-Autopilot/src/modules/simulation/pwm_out_sim/module_sim.yaml && /usr/bin/cmake -E touch /home/barracuda/pix/PX4-Autopilot/build/px4_sitl_default/ROMFS/romfs_copy.stamp
CMake Error: cmake version 3.10.2
Usage: /usr/bin/cmake -E <command> [arguments...]
Available commands:
capabilities - Report capabilities built into cmake in JSON format
chdir dir cmd [args...] - run command in a given directory
compare_files file1 file2 - check if file1 is same as file2
copy <file>... destination - copy files to destination (either file or directory)
copy_directory <dir>... destination - copy content of <dir>... directories to 'destination' directory
copy_if_different <file>... destination - copy files if it has changed
echo [<string>...] - displays arguments as text
echo_append [<string>...] - displays arguments as text but no new line
env [--unset=NAME]... [NAME=VALUE]... COMMAND [ARG]...
- run command in a modified environment
environment - display the current environment
make_directory <dir>... - create parent and <dir> directories
md5sum <file>... - create MD5 checksum of files
sha1sum <file>... - create SHA1 checksum of files
sha224sum <file>... - create SHA224 checksum of files
sha256sum <file>... - create SHA256 checksum of files
sha384sum <file>... - create SHA384 checksum of files
sha512sum <file>... - create SHA512 checksum of files
remove [-f] <file>... - remove the file(s), use -f to force it
remove_directory dir - remove a directory and its contents
rename oldname newname - rename a file or directory (on one volume)
server - start cmake in server mode
sleep <number>... - sleep for given number of seconds
tar [cxt][vf][zjJ] file.tar [file/dir1 file/dir2 ...]
- create or extract a tar or zip archive
time command [args...] - run command and return elapsed time
touch file - touch a file.
touch_nocreate file - touch a file but do not create it.
Available on UNIX only:
create_symlink old new - create a symbolic link new -> old
[12/873] Generating uORB topic headers
Makefile:232: recipe for target 'px4_sitl' failed
make: *** [px4_sitl] Error 1
