Questions about PositionSmoothing
Hi All,
I have been looking closely at the PositionSmoothing code in PX4 to get a better understanding of some of the odd behavior we are seeing in our drone. Specifically, strange behavior around loiter waypoints. Strange behavior aside, I realize I simply don’t understand what PositionSmoothing is trying to do? It looked at first like it was implementing an L1 controller, but then it deviates from that. Is there a guide or documentation anywhere on what the intentions of the algorithm are?
Some oddities I don’t understand:
  • The calculated velocity’s magnitude and direction in the position smoothing don’t correspond to the same vector. The direction is pointing at the L1 point or the Target (depending on whether or not the craft is currently facing the target). The calculated velocity magnitude comes from assuming youre flying toward an arc within the radius of the current target waypoint. I don’t understand why this would make sense when you are using the L1 point as the crossing point instead of the target. In the traditional L1 algorithm, this vector toward the crossing point is used as an acceleration applied to a nominal velocity. that doesn’t seem to be what’s going on here. The relevant codeblock in PositionSmoothing.cpp
	// Interface: A valid position setpoint generates a velocity target using conservative motion constraints.
	// If a velocity is specified, that is used as a feedforward to track the position setpoint
	// (ie. it assumes the position setpoint is moving at the specified velocity)
	// If the position setpoints are set to NAN, the values in the velocity setpoints are used as velocity targets: nothing to do here.
	auto &target = waypoints[1];
	const bool xy_target_valid = PX4_ISFINITE(target(0)) && PX4_ISFINITE(target(1));
	const bool z_target_valid = PX4_ISFINITE(target(2));
	Vector3f velocity_setpoint = feedforward_velocity_setpoint;
	if (xy_target_valid && z_target_valid) {
		// Use 3D position setpoint to generate a 3D velocity setpoint
		Vector3f pos_traj(_trajectory[0].getCurrentPosition(),
				  _trajectory[1].getCurrentPosition(),
				  _trajectory[2].getCurrentPosition());
		const Vector3f crossing_point = is_single_waypoint ? target : _getCrossingPoint(position, waypoints);
		const Vector3f u_pos_traj_to_dest{(crossing_point - pos_traj).unit_or_zero()};
		float xy_speed = _getMaxXYSpeed(waypoints);
		const float z_speed = _getMaxZSpeed(waypoints);
		if (!is_single_waypoint && _isTurning(target)) {
			// Limit speed during a turn
			xy_speed = math::min(_max_speed_previous, xy_speed);
		} else {
			_max_speed_previous = xy_speed;
		Vector3f vel_sp_constrained = u_pos_traj_to_dest * sqrtf(xy_speed * xy_speed + z_speed * z_speed);
		math::trajectory::clampToXYNorm(vel_sp_constrained, xy_speed, 0.5f);
		math::trajectory::clampToZNorm(vel_sp_constrained, z_speed, 0.5f);
		for (int i = 0; i < 3; i++) {
			// If available, use the existing velocity as a feedforward, otherwise replace it
			if (PX4_ISFINITE(velocity_setpoint(i))) {
				velocity_setpoint(i) += vel_sp_constrained(i);
			} else {
				velocity_setpoint(i) = vel_sp_constrained(i);
  • The velocity calculations to compute the speeds always assume that the next waypoint is the final waypoint and that it should be stopped at. If you work through the algorithm below, this is why the craft seems to not fly smoothly through waypoints? I am unsure. Either way, I don’t understand how this was supposed to work. Relevant codeblock in TrajectoryConstraints.hpp
 * Compute the maximum allowed speed at the waypoint assuming that we want to
 * connect the two lines (current-target and target-next)
 * with a tangent circle with constant speed and desired centripetal acceleration: a_centripetal = speed^2 / radius
 * The circle should in theory start and end at the intersection of the lines and the waypoint's acceptance radius.
 * This is not exactly true in reality since Navigator switches the waypoint so we have to take in account that
 * the real acceptance radius is smaller.
inline float computeStartXYSpeedFromWaypoints(const Vector3f &start_position, const Vector3f &target,
		const Vector3f &next_target, float exit_speed, const VehicleDynamicLimits &config)
	const float distance_target_next = (target - next_target).xy().norm();
	const bool target_next_different = distance_target_next  > 0.001f;
	const bool waypoint_overlap = distance_target_next < config.xy_accept_rad;
	const bool has_reached_altitude = fabsf(target(2) - start_position(2)) < config.z_accept_rad;
	const bool altitude_stays_same = fabsf(next_target(2) - target(2)) < config.z_accept_rad;
	float speed_at_target = 0.0f;
	if (target_next_different &&
	    !waypoint_overlap &&
	    has_reached_altitude &&
	    altitude_stays_same
		const float alpha = acosf(Vector2f((target - start_position).xy()).unit_or_zero().dot(
						  Vector2f((target - next_target).xy()).unit_or_zero()));
		const float safe_alpha = constrain(alpha, 0.f, M_PI_F - FLT_EPSILON);
		float accel_tmp = config.max_acc_xy_radius_scale * config.max_acc_xy;
		float max_speed_in_turn = computeMaxSpeedInWaypoint(safe_alpha, accel_tmp, config.xy_accept_rad);
		speed_at_target = min(max_speed_in_turn, exit_speed, config.max_speed_xy);
	float start_to_target = (start_position - target).xy().norm();
	float max_speed = computeMaxSpeedFromDistance(config.max_jerk, config.max_acc_xy, start_to_target, speed_at_target);
	return min(config.max_speed_xy, max_speed);
 * This function computes the maximum speed XY that can be travelled, given a set of waypoints and vehicle dynamics
 * The first waypoint should be the starting location, and the later waypoints the desired points to be followed.
 * @param waypoints the list of waypoints to be followed, the first of which should be the starting location
 * @param config the vehicle dynamic limits
 * @return the maximum speed at waypoint[0] which allows it to follow the trajectory while respecting the dynamic limits
template <size_t N>
float computeXYSpeedFromWaypoints(const Vector3f waypoints[N], const VehicleDynamicLimits &config)
	static_assert(N >= 2, "Need at least 2 points to compute speed");
	float max_speed = 0.f;
	for (size_t j = 0; j < N - 1; j++) {
		size_t i = N - 2 - j;
		max_speed = computeStartXYSpeedFromWaypoints(waypoints[i],
				waypoints[i + 1],
				waypoints[min(i + 2, N - 1)],
				max_speed, config);
	return max_speed;
I cannot tell if I am misunderstanding the intentions behind the algorithms and would appreciate guidance!
Hi @profxavr ,
  1. It’s not really close to the L1 algorithm, we just got inspired by the first step where a point is found on the line by looking at the intersection between a line segment of some fixed length in front of the drone (L1 distance) and the line segment between 2 waypoints. This vector (current position of the trajectory to crossing point) is then just used to give a direction to the trajectory generator. It is also assumed that the velocity must be constant during a turn.
  2. The PositionSmoothing class has only access to 3 waypoints: the previous one, the current target and the one after that (“next”). Since it doesn’t know if “next” is the final one, it just assumes that it will have to stop there.
    If current and next are far enough, the drone shouldn’t slow down when passing the current waypoint if they are -almost- aligned. If the waypoints are close, then yes, the drone will always slow down just in case “next” is really a final waypoint.
    By increasing the acceptance radius, you can also allow the drone to fly faster in waypoints that are not aligned.
A couple of questions:
  • Could you describe a bit more the behavior you see on your drone?
  • Were you able to reproduce this in simulation as well?
  • Which PX4 version are you using?
Hi! Thanks for the reply!
  1. When it’s turning, despite the fact that the velocity vector direction changes, the calculated magnitude is still the same right? I didn’t understand that bit. I was also wondering, since L1 was implemented for the fixed wings, why not also just use it for the quad?
  2. Even if you increase the acceptance radius, you still get a strange stopping and starting effect as the drone tries to figure out what to do. I know the “triplets” concept is really deeply ingrained in PX4, so it’s difficult to get more out of it. I suppose that is what “offboard” mode is for, if you want a trajectory that is smoothed over a larger horizon?
  • Ultimately i think the behavior we were seeing was due to incorrect jerk limits. The drone systematically overshoots waypoints in mission mode with the same sort of “look” if you will. The Position Smoothing “carrot” was braking faster than the drone could follow so it overshot every time. This hasn’t been fully fixed on our end, but the issue has moved elsewhere.
  • Yes it was consistent in simulation.
  • v1.13 with some custom edits.
The desired speed, yes, but since the trajectory smoothing in parameterized in North and East components and that they have jerk and accelerations limits, there is not guarantee that the norm of the smoothed velocity vector is exactly constant (but it’s really close).
L1 works well if the vehicle always has a forward velocity (a plane for example) but for multirotors we don’t always want to fly at cruise speed; if the use wants for some reason to precisely reach the center of a waypoint, the multirotor needs to decelerate and -almost- stop. It would also have been possible to have L1 for lateral guidance and some other guidance on the forward direction but it was simpler to just use time-synchronized jerk-limited trajectories in 3D and then send those to the position and velocity controllers. Since we know the reference position/velocity/acceleration/jerk trajectories they can also be used in the controllers as feedforward.
yes, you can use offboard for that or rather directly communicate through the DDS bridge and set the trajectory_setpoint uORB topic
We also talked about having a path following guidance for multirotors that would accept Dubins paths.
Ok, yes, you need to tune the parameters to always have a feasible trajectory. Ideally, when well tuned the drone should track that trajectory almost perfectly (in position, velocity and acceleration).
We just released v1.15, you should give it a try!
