I read the following in github #11327 regarding SYS_COMPANION being depricated.
* TELEM2 as companion computer link (deprecated)
* This parameter is deprecated. Do not change it, use the more generic serial
* configuration parameters instead.
* This parameter is deprecated and will be removed after 1.9.0. Use the generic serial
* configuration parameters instead (e.g. MAV_0_CONFIG, MAV_0_MODE, etc.).
Does this mean we will no longer use TELEM2 to connect companion computers? If not then what port will be used?
I currently use RPi’s on all my drones connected to TELEM2 to send missions to PX4. What changes will I have to make when v1.9.0 comes out?
Thanks,
Joe
