Hi, everyone.
I research TECS in PX4 source code(ver 1.11.2).
I confused When i read function.
→ void TECS::_update_energy_estimates()
Specific energy rate setpoint is derived like under line.
_SKE_rate_setpoint = _tas_state * _TAS_rate_setpoint;
But, I don’t understand why _tas_state was used?
Because setpoint mean command so that it must use _TAS_setpoint_adj.
Someone know reason?
Also, is STE_to_throttle and climb_angle_to_SEB_rate used like P gain?
sfuhrer
December 13, 2021, 8:24am
3
There is a bit of explanation here: TECS: fix calculation of _SKE_rate_setpoint by sfuhrer · Pull Request #15735 · PX4/PX4-Autopilot · GitHub
Yeah one could say so.
Thanks for the comment.
I can see why the code is structured that way.
But still mathematically, _TAS_setpoint_adj seems to be more correct than _tas_state.
sfuhrer
December 13, 2021, 10:29am
5
If I got it correctly then the idea is to linearize the setpoint around the current airspeed (_tas_state). It has the effect that the TAS_rate_setpoint to SKE_rate_setpoint mapping changes depending on the current airspeed. The faster you fly, the larger is the change on SKE_rate_setpoint (in absolute numbers).
I don’t understand your comments that mapping changes depending on the current airspeed.
I don’t understand your comments that linearize the setpoint around the current airspeed (_tas_state).
y = _SKE_rate_setpoint, C = _TAS_setpoint_adj(constant), x = _tas_state, _TAS_rate_setpoint = _TAS_setpoint_adj - _tas_state (ignore gain).
We can derive equation like this :
_SKE_rate_setpoint = _TAS_setpoint_adj * (_TAS_setpoint_adj - _tas_state). → y = C * (C - x) = -C*x+ C^2
y = ax + b(linear equation)
It was derived like this : (if _tas_state were used)
y = x* (C - x) = -x^2 + C * x
y = ax^2 + bx + c(quadratic equation)
So, I don’t understand your comments. Using _TAS_setpoint_adj is a linear equation. It quadratic equation If _tas_state is used.
