QGC on raspberry pi
Hello and thank you for reading.
Is there any one out there that has successfully installed QGC on to a raspberry pi. Talking about RPI 4 here?
Yes, but only V3.5.6
I’m looking for a QGC that works with a raspberry PI, but I can’t find one.
I’d like to know how to do this in detail.
DId you just downloaded the normal Llinux image?
Anyone have the latest QGC release successfully working on a RPi4? How well does it run?
Hi
Would you please tell us how did you manage to install qgc on rpi? Thanks!
Same here, It seems possible to compile it with qt but there must be an easier way.
Since ubuntu runs well on Pi4 I am surprised not to see a nice version of QGC on it.
Wait and see.
lo instale en la raspberry pi 4 en raspbian 32 bits con mono pero es muy lenta.
Lo tengo ahora con manjaro 64 bits y funciona genial.
Instala manjaro minimal, despues el escritorio lxqt, ellos lo hicieron pot ti, esta listo en los repos arch4.
Eso es todo
Hey guys, just updating here if anyone is using 20.10 (Ubuntu 20.10 (Groovy Gorilla)) on Raspberry Pi CM4. I’ve tested it and it works decently well on the Rpi CM4 and since it has the same archi as Rpi 4, I think QGC would work on it too!
Here is a compiled version (using QT 5.14.2) and release
Hi!
Is there a video or rutorial to do thi
Thx!
qgc on rpi 4
