I am trying to use PX4 SITL to validate an enhancement for survey missions, but I need to have the images geotagged, unfortunately, they are coming without it.
I tried to use the log file and the images but it didn’t work either.
I noticed that the instructions that mention geotagged images refer to the plane_cam model, but the typhoon_h480 (which I am using) uses the same plugin:
<plugin name="GeotaggedImagesPlugin" filename="libgazebo_geotagged_images_plugin.so">
<robotNamespace>typhoon_h480</robotNamespace>
<interval>1</interval>
<width>3840</width>
<height>2160</height>
<maximum_zoom>8.0</maximum_zoom>
</plugin>
I would appreciate deeply if someone could help me to get this working. I plan to run the geotagged images of mcmillan airfield with different parameters on a photogrammetry software and compare the results, hence the use of SITL, it gives me an 100% controlled environment to evaluate the performance differences.
