Px4 + mavsdk vtol velocity control
hello people, i am unable to control the velocity of the vtol. i am trying to direct the vtol by using set_velocity_body().
// Example showing how to make a VTOL takeoff, transition to fixedwing, loiter
// for a bit, and then transition back and return to launch.
#include <chrono>
#include <cstdint>
#include <iostream>
#include <thread>
#include <cmath>
#include <future>
#include <mavsdk/mavsdk.h>
#include <mavsdk/plugins/action/action.h>
#include <mavsdk/plugins/telemetry/telemetry.h>
#include <mavsdk/plugins/offboard/offboard.h>
using std::this_thread::sleep_for;
using std::chrono::seconds;
using namespace mavsdk;
double position_m;
void usage(const std::string& bin_name)
    std::cerr << "Usage : " << bin_name << " <connection_url>\n"
              << "Connection URL format should be :\n"
              << " For TCP : tcp://[server_host][:server_port]\n"
              << " For UDP : udp://[bind_host][:bind_port]\n"
              << " For Serial : serial:///path/to/serial/dev[:baudrate]\n"
              << "For example, to connect to the simulator use URL: udp://:14540\n";
std::shared_ptr<System> get_system(Mavsdk& mavsdk)
    std::cout << "Waiting to discover system...\n";
    auto prom = std::promise<std::shared_ptr<System>>{};
    auto fut = prom.get_future();
    // We wait for new systems to be discovered, once we find one that has an
    // autopilot, we decide to use it.
    mavsdk.subscribe_on_new_system([&mavsdk, &prom]() {
        auto system = mavsdk.systems().back();
        if (system->has_autopilot()) {
            std::cout << "Discovered autopilot\n";
            // Unsubscribe again as we only want to find one system.
            mavsdk.subscribe_on_new_system(nullptr);
            prom.set_value(system);
    // We usually receive heartbeats at 1Hz, therefore we should find a
    // system after around 3 seconds max, surely.
    if (fut.wait_for(seconds(3)) == std::future_status::timeout) {
        std::cerr << "No autopilot found.\n";
        return {};
    // Get discovered system now.
    return fut.get();
int main(int argc, char** argv)
    if (argc != 2) {
        usage(argv[0]);
        return 1;
    Mavsdk mavsdk;
    ConnectionResult connection_result = mavsdk.add_any_connection(argv[1]);
    if (connection_result != ConnectionResult::Success) {
        std::cerr << "Connection failed: " << connection_result << '\n';
        return 1;
    auto system = get_system(mavsdk);
    if (!system) {
        return 1;
    // Instantiate plugins.
    auto telemetry = Telemetry{system};
    auto action = Action{system};
    // We want to listen to the altitude of the drone at 1 Hz.
    const Telemetry::Result set_rate_result = telemetry.set_rate_position(1.0);
    if (set_rate_result != Telemetry::Result::Success) {
        std::cerr << "Setting rate failed: " << set_rate_result << '\n';
        return 1;
    // Set up callback to monitor altitude.
    telemetry.subscribe_position([](Telemetry::Position position) {
        std::cout << "Altitude: " << position.relative_altitude_m << " m\n";
        position_m = position.relative_altitude_m;
    // Wait until we are ready to arm.
    while (!telemetry.health_all_ok()) {
        std::cout << "Waiting for vehicle to be ready to arm...\n";
        sleep_for(seconds(1));
    // Arm vehicle
    std::cout << "Arming.\n";
    const Action::Result arm_result = action.arm();
    if (arm_result != Action::Result::Success) {
        std::cerr << "Arming failed: " << arm_result << '\n';
        return 1;
    // Take off
    float desired_altitude = 20.0f;
    action.set_takeoff_altitude(desired_altitude);
    std::cout << "Taking off.\n";
    const Action::Result takeoff_result = action.takeoff();
    if (takeoff_result != Action::Result::Success) {
        std::cerr << "Takeoff failed:n" << takeoff_result << '\n';
        return 1;
    while (true)
        // Wait while it takes off.
        if (position_m >= desired_altitude * 0.95){
            std::cout << "Transition to fixedwing.\n";
            const Action::Result fw_result = action.transition_to_fixedwing();
            if (fw_result != Action::Result::Success) {
                std::cerr << "Transition to fixed wing failed: " << fw_result << '\n';
                return 1;
            else if (fw_result == Action::Result::Success)
                break;
        }else {
    // Let it transition and start loitering.
    sleep_for(seconds(10));
    auto offboard = Offboard{system};
    Offboard::VelocityBodyYawspeed stay{};
    offboard.set_velocity_body(stay);
    // Offboard modunu başlatmadan önce, offboard kontrolünün başarılı olacağından emin olun
    Offboard::Result offboard_result = offboard.start();
    if (offboard_result != Offboard::Result::Success) {
        std::cerr << "Offboard modu baslatilamadi: " << offboard_result << std::endl;
        return 1;
    std::cout << "Offboard modu baslatildi. Saga donud yapiliyor..." << std::endl;
    // Sağa dönüş için y hızını pozitif yapın
    Offboard::VelocityBodyYawspeed saga_donus{0.0f, 5.0f, 0.0f, 0.0f};
    offboard.set_velocity_body(saga_donus);
    sleep_for(seconds(5)); // 5 saniye boyunca sağa dönüş yap
    std::cout << "Şimdi sola dönüş yapılıyor..." << std::endl;
    // Sola dönüş için y hızını negatif yapın
    Offboard::VelocityBodyYawspeed sola_donus{0.0f, -5.0f, 0.0f, 0.0f};
    offboard.set_velocity_body(sola_donus);
    sleep_for(seconds(5)); // 5 saniye boyunca sola dönüş yap
    // Yukarı hareket için down_m_s negatif yapılır
    Offboard::VelocityBodyYawspeed yukari_hareket{0.0f, 0.0f, 2.0f, 0.0f};
    std::cout << "Yukarı hareket ediliyor..." << std::endl;
    offboard.set_velocity_body(yukari_hareket);
    sleep_for(seconds(5)); // 5 saniye boyunca yukarı hareket et
    // Aşağı hareket için down_m_s pozitif yapılır
    Offboard::VelocityBodyYawspeed asagi_hareket{0.0f, 0.0f, -2.0f, 0.0f};
    std::cout << "Aşağı hareket ediliyor..." << std::endl;
    offboard.set_velocity_body(asagi_hareket);
    sleep_for(seconds(5)); // 5 saniye boyunca aşağı hareket et
    // Offboard modunu durdur
    offboard_result = offboard.stop();
        std::cerr << "Offboard modu durdurulamadı: " << offboard_result << std::endl;
        return 1;
    std::cout << "Offboard modu durduruldu." << std::endl;
    std::cout << "Burada1 \n";
    // Let's stop before reaching the goto point and go back to hover.
    std::cout << "Transition back to multicopter...\n";
    const Action::Result mc_result = action.transition_to_multicopter();
    std::cout << "Burada2 \n";
    if (mc_result != Action::Result::Success) {
        std::cerr << "Transition to multi copter failed: " << mc_result << '\n';
        return 1;
    const Action::Result mc_result2 = action.transition_to_multicopter();
        std::cerr << "Transition to multi copter failed: " << mc_result2 << '\n';
        return 1;
    // Wait for the transition to be carried out.
    // Now just land here.
    std::cout << "Landing...\n";
    const Action::Result land_result = action.land();
    if (land_result != Action::Result::Success) {
        std::cerr << "Land failed: " << land_result << '\n';
        return 1;
    // Wait until disarmed.
    while (telemetry.armed()) {
        std::cout << "Waiting for vehicle to land and disarm\n.";
    std::cout << "Disarmed, exiting.\n";
    return 0;
px4 version: 1.16.0alpha
mavsdk version: 1.4.17
ros noetic
