PX4 Dev Call: Feb 18, 2026 (Team sync, and Community Q&A)
PX4 Sync / Q&A - 2026-02-18T16:00:00Z
Agenda
  • Announcements
  • Future Events
  • Flight Testing Update
  • Release Discussion
  • Bug Report / Q&A
Announcements
Future Events
Testing Issue Reports
Release Discussion
v1.17.0-beta1
:warning: Given how the testing has been positive so far, we are going to promote the beta1 to rc1 before the next dev call.
Community Q&A / PRs for Review
Q&A/Discussion:
PRs:
Issues:
PRs for Review / Updates (Ramon):
Introduce AGENTS.md for better context guidance, pointing to the right locations in our docs and updating our docs for up to date and accurate conventions. Looking for feedback.
S3 Stable Firmware Fix - Fixed the issue where QGC users got beta firmware when selecting β€œstable”. Tags no longer overwrite stable firmware in S3. Backported and merged to 1.17.
PX4 SITL .deb Package - New px4_sitl_sih board target with .deb packaging, composite build action, and hardened CI permissions. Looking for feedback.
Docs - README modernized, release process documented, Ubuntu/macOS dev env guides rewritten, docs CI orchestrator merged.
Other merged fixes:
CI Orchestrator - Consolidates all CI workflows into a 4-tier architecture with ccache and S3 caching across all jobs. Currently working on optimizing total run time from 60 min to under 20 min. VTOL/tailsitter SITL tests temporarily disabled while fixing test
reliability
Firmware Manifest - Unified manifest bundled into .px4 files for release discovery. Adds label_pretty and firmware_category fields to board configs.
Pixhawk 6X-RT standard alignment
Context
Questions
  • What are our options given the Secure Element change does not appear to risk altering flight dynamics. FMU Sensor U10 (SE) changed. We are using the Secure Element driver with SE051 and SE052 compatibility, different Applet versions, similar base API for our use cases). Sensor set 3.1? Or is this explicitly not allowed?
The trademark shall only be used for compliant products and in combination with a
signed adopter agreement.
Implementations of the standard must be compliant with the full specification.
  • Is Pixhawk Standard supported Board still an option for us given the Secure Element change? We’d rather start with Pixhawk Standard Board than Manufacturer Supported given the delta is small, if possible.
  • We can provide samples for testing regardless. Have been in communication with Gerald from NXP already.
