PX4 Dev Call: Feb 11, 2026 (Team sync, and Community Q&A)
PX4 Sync / Q&A - 2026-02-11T16:00:00Z
Agenda
  • Announcements
  • Future Events
  • Flight Testing Update
  • Release Discussion
  • Bug Report / Q&A
Announcements
Future Events
:warning:CFP Extended :warning: - PX4 Developer Summit
Release Discussion
v1.17.0-beta1
:warning: Given how the testing has been positive so far we are going to promote the beta1 to rc1 before the next dev call.
Community Q&A / PRs for Review
Q&A/Discussion:
PRs:
Issues:
looking for information here, using premade Vtol titlrotor config with air nozzles and valves to open/close air flow linear for thrust instead of propellers. The problem is that the valve is servo controlled and has a considerable deadzone that I believe may be messing with tuning/position mode and causing lack of stability. is there a deadzone servo parameter or am I missing something here?
when the valve is going from one direction to the other direction there is about 2% of movement in the handle before the valve moves internally
Is there a way to precisely set motor value for thrust measurement values? Currently doing this by actuators tab
You could map the throttle to a switch on a RC, and the set the exact PWM value from there. Then it should be easy to do tests.
