If you take over 5 minutes for the question, please continue in Discord or a Github Issue.
Q.1: VIO bridge alternative
Auterion repo is now private, is there an alternative?
Answer: Post on discord & maybe people may know there!
Q.2: QGC customizing a function - Anthony
To export KML files? How to get started in modifying the QGC code?
Object detection use case: Requiring confidence parameter, etc.
Goal: Handle a specific file (e.g. KML) that is getting passed through. There’s a rectangular pattern. And want to have a function to generate KML file with certain parameters.
Answer: There’s “Polygon tools” code section. Farhang will answer in DM.
Q.3: How to suppress preflight check? - Farhang
Currently the disarmed PWM value equals failsafe PWM value. Leading to unintended failsafe trigger.
In Gazebo, it’s now hard to determine if vehicle is in failsafe mode via PWM output value. Starting from v1.12, the parachute package in SITL Gazebo isn’t working.
