Is it possible to set the range on the things being tested for preflight?
For example - GPS horizontal or vertical position drift?
Or - Height estimate not stable?
Also - I’m using a CubePilot Orange Cube - and I’ve received no warnings on it being at the necessary temp. Are there parameters that set the required flight controller temp?
Thank you!
