No Bidirectional DShot / EDT telemetry on PX4 (Works on Betaflight)
Hi everyone,
I am having an issue receiving Extended DShot Telemetry PX4 with a GEPRC 80A ESC.
Status Summary:
  • BDShot eRPM on PX4: Working properly. Motor RPM is correctly updated in esc_status.
  • Betaflight: EDT works on Betaflight with the exact same esc.
  • PX4 EDT: Extended telemetry is missing or not parsed in PX.
Console Output:
NuttShell (NSH) NuttX-11.0.0
nsh> dshot status
INFO  [dshot] DShot Driver Status
INFO  [dshot] Configuration:
INFO  [dshot]   Output Mask:        0x01 (1 channels)
INFO  [dshot]   BDShot Telemetry:   Enabled
INFO  [dshot]   Serial Telemetry:   Disabled
INFO  [dshot]   Extended DShot:     Enabled
INFO  [dshot]   ESC Type:           Unknown (0)
INFO  [dshot]   3D Mode:            Disabled
INFO  [dshot]   Motor Poles:
INFO  [dshot]     Motor 1: 14 poles
INFO  [dshot] Telemetry Status:
INFO  [dshot]   Ch   Motor  BDShot   Serial   BDShot Err   Serial Err
INFO  [dshot]   1    1      Online   -        741536       0
INFO  [dshot]   EDT Requested Mask (motor order): 0x01
INFO  [dshot] Bidirectional DShot Hardware:
INFO  [arch_dshot] dshot driver stats:
INFO  [arch_dshot] BDShot channel mask: 0x0001
INFO  [arch_dshot] Ch0: read_ok 155167, fail_crc 741536
INFO  [arch_dshot] BDShot EDT
INFO  [arch_dshot] Ch0:  eRPM: 763Hz  Temp: 0C (0.0Hz)  Volt: 0.00V (0.0Hz)  Curr: 0.0A (0.0Hz)
INFO  [dshot] Mixer Information:
INFO  [mixer_module] Param prefix: PWM_AUX
control latency: 898682 events, 285030989us elapsed, 317.17us avg, min 308us max 530us 3.482us rms
INFO  [mixer_module] Switched to rate_ctrl work queue
Channel Configuration:
Channel  0: func: 101, value: 0.00, failsafe: 0.00, disarmed: 0, min: 109, max: 1999, center: 65535
Channel  1: func:   0, value: 0.00, failsafe: 0.00, disarmed: 0, min: 109, max: 1999, center: 65535
Channel  2: func:   0, value: 0.00, failsafe: 0.00, disarmed: 0, min: 109, max: 1999, center: 65535
Channel  3: func:   0, value: 0.00, failsafe: 0.00, disarmed: 0, min: 109, max: 1999, center: 65535
Channel  4: func:   0, value: 0.00, failsafe: 0.00, disarmed: 0, min: 109, max: 1999, center: 65535
Channel  5: func:   0, value: 0.00, failsafe: 0.00, disarmed: 0, min: 109, max: 1999, center: 65535
INFO  [dshot] Performance Counters:
dshot: cycle: 898712 events, 22673736us elapsed, 25.23us avg, min 19us max 462us 1.256us rms
dshot: bdshot recv: 895216 events
dshot: bdshot error: 740208 events
TOPIC: esc_status
 esc_status
    timestamp: 1282018035 (0.000960 seconds ago)
    counter: 58506
    esc_online_flags: 1 (0b1)
    esc_armed_flags: 0
    esc_count: 1
    esc_connectiontype: 5
  esc[0] (esc_report):
    timestamp: 1282018033 (0.018264 seconds ago)
    esc_errorcount: 741536
    esc_rpm: 0
    esc_voltage: 0.00000
    esc_current: 0.00000
    esc_temperature: 0.00000
    motor_temperature: 0
    failures: 0
    esc_state: 0
    actuator_function: 101
    esc_power: 0
Does PX4 currently support Extended DShot Telemetry (EDT) for BLHeli ESCs to report voltage, current, and temperature over BDShot, or is Bidirectional DShot in PX4 strictly limited to eRPM feedback at the moment?
It’s supported, set the param DSHOT_BIDIR_EDT
Thanks for the reply. DSHOT_BIDIR_EDT is actually already enabled.
Just to clarify regarding the ESC firmware: the ESC came with BLHeli_S by default, but I flashed Bluejay onto it specifically to enable EDT support.
EDT works fine in Betaflight with this setup, but I am still unable to get EDT telemetry working in PX4.
Which flight controller are you using?
For betaflight testing I’ve used GEPRC F722.
For PX4 testing I’ve used Cube Orange.
Try this
