New parameters
I have a new firmware on my drone that defines some new parameters. I’ve added the definition to the PX4ParameterFactMetaData.xml file and made sure it passes xmllint (minus dtd info). When debugging is enabled I see that the definitions are loaded, but when trying to access the parameters (using for example FactTextField), there are no units defined in the text field, and when I try to modify the values (in this case in the SafetyComponent page) it hangs the page. It saves the value to the remote device, but I can’t leave the page. Any help?
(as an aside… I did the same thing using an old QGC4 build tree, and it worked)
Relevant code:
{this is in the SafetyComponent.qml}
property Fact _myNewVariable1: controller.getParameterFact(-1, "MY_NEW_VAR_1", false)
QGCLabel {
    text: qsTr("These Are My New Variables")
Rectangle {
    width:       mainRow.width + (_margins * 2)
    height:      myVariableGrid.height + (_margins * 2)
    color:       qgcPal.windowShade
    Row {
        spacing: _margins
        anchors.centerIn: parent
        Item {
            width:   _imageWidth
            height:  _imageHeight
            anchors.verticalCenter: parent.verticalCenter
            Image {
                mipmap:       true
                fillMode:     Image.PreserveAspectFit
                source:       /qmlimages/myvariableImage.svg"
        GridLayout {
            columns:                2
            QGCLabel {
                text:           qsTr("My First New Variable")
                enabled:        controller.vehicle
                Layout.fillWidth:   true
            QGCComboBox {
                model:    [qsTr("Disabled"), qsTr("Enabled")]
                enabled:            _myNewVariable1
                Layout.minimumWidth:_editFieldWidth
                currentIndex: _myNewVariable1 ?(_myNewVariable1.value === 0 ? 0 : 1) : 0
                onActivated: (index) => {
                    if(_myNewVariable1) {
                        _myNewVariable1.value = index > 0 ? 1 : 0
         QGCLabel {
             text:         qsTr("Edit Variable 2")
             enabled:      _myNewVariable1 ? _myNewVariable1.value : false
         FactTextField {
             fact: controller.getParameterFact(-1, "MY_NEW_VAR_2")
         QGCLabel {
             text:           qsTr("Edit Variable 3")
         FactTextField {
             fact: controller.getParameterFact(-1, "MY_NEW_VAR_3")
and the relevant XML changes are in PX4ParameterFactMetaData.xml
<group name="My 3 New Variables">
    <parameter name="MY_NEW_VAR_1" default="0" type="INT32">
      <short_desc>Enable Variable 1</short_desc>
      <long_desc>Enable Variable 1</long_desc>
      <min>0</min>
      <max>1</max>
      <values>
        <value code="0">Disabled</value>
        <value code="1">Enabled</value>
      </values>
    </parameter>
    <parameter name="MY_NEW_VAR_2" default="0" type="FLOAT">
      <short_desc>Modify Variable 2</short_desc>
      <long_desc>Modify Variable 2</long_desc>
      <min>0</min>
      <max>360</max>
      <unit>deg</unit>
    </parameter>
    <parameter name="MY_NEW_VAR_3" default="0.0" type="FLOAT">
      <short_desc>Edit Variable 3</short_desc>
      <long_desc>Edit Variable 3</long_desc>
      <min>0</min>
      <unit>m</unit>
    </parameter>
  </group>
There have been several looks at my post, but no answers. I guess there is nothing obviously wrong with my code. Maybe one of the maintainers can give a look see?
