I created a new module named fortests. It contains CMakeLists.txt
set(CMAKE_CXX_STANDARD 14)
px4_add_module(
MODULE
fortests
MAIN
fortests
SRCS
fortests.cpp
DEPENDS
and fortests.cpp file
#include <vector>
#include <px4_module.h>
extern "C" __EXPORT int fortests_main(int argc, char *argv[]);
return 0;
Also I declared the module in boards/px4/fmu-v5/default.cmake as
MODULES
attitude_estimator_q
camera_feedback
fortests
When I try to compile px4, I have the following error
~/px4$ make px4_fmu-v5_default
[1/520] Building CXX object src/modules/fortests/CMakeFiles/fortests.dir/fortests.cpp.obj
FAILED: src/modules/fortests/CMakeFiles/fortests.dir/fortests.cpp.obj
/home/msurov/etc/gcc-arm-none-eabi-7-2017-q4-major/bin/arm-none-eabi-g++ -DCONFIG_ARCH_BOARD_PX4_FMU_V5 -DMODULE_NAME=\"fortests\" -DPX4_MAIN=fortests_app_main -D__CUSTOM_FILE_IO__ -D__DF_NUTTX -D__PX4_NUTTX -D__STDC_FORMAT_MACROS -isystem ../../platforms/nuttx/NuttX/include/cxx -isystem NuttX/nuttx/include/cxx -isystem NuttX/nuttx/include -I../../boards/px4/fmu-v5/src -I. -Isrc -Isrc/lib -Isrc/modules -I../../src -I../../src/include -I../../src/lib -I../../src/lib/DriverFramework/framework/include -I../../src/lib/matrix -I../../src/modules -I../../src/platforms -I../../src/platforms/common -INuttX/nuttx/arch/arm/src/armv7-m -INuttX/nuttx/arch/arm/src/chip -INuttX/nuttx/arch/arm/src/common -INuttX/apps/include -Iexternal/Install/include -mcpu=cortex-m7 -mthumb -mfpu=fpv5-d16 -mfloat-abi=hard -Os -DNDEBUG -g -fdata-sections -ffunction-sections -fomit-frame-pointer -fno-signed-zeros -fno-trapping-math -freciprocal-math -fno-math-errno -fno-strict-aliasing -fvisibility=hidden -include visibility.h -Wall -Wextra -Werror -Warray-bounds -Wcast-align -Wdisabled-optimization -Wdouble-promotion -Wfatal-errors -Wfloat-equal -Wformat-security -Winit-self -Wlogical-op -Wpointer-arith -Wshadow -Wuninitialized -Wunknown-pragmas -Wunused-variable -Wno-implicit-fallthrough -Wno-missing-field-initializers -Wno-missing-include-dirs -Wno-unused-parameter -fdiagnostics-color=always -fno-builtin-printf -fno-strength-reduce -Wformat=1 -Wunused-but-set-variable -Wno-format-truncation -fcheck-new -fno-exceptions -fno-rtti -fno-threadsafe-statics -Wreorder -Wno-overloaded-virtual -D__STDC_VERSION__=199901L -nostdinc++ -Wframe-larger-than=1024 -std=gnu++14 -MD -MT src/modules/fortests/CMakeFiles/fortests.dir/fortests.cpp.obj -MF src/modules/fortests/CMakeFiles/fortests.dir/fortests.cpp.obj.d -o src/modules/fortests/CMakeFiles/fortests.dir/fortests.cpp.obj -c ../../src/modules/fortests/fortests.cpp
../../src/modules/fortests/fortests.cpp:1:10: fatal error: vector: No such file or directory
#include <vector>
compilation terminated.
Of course, I can add the missing directories into my cmakelists.txt as include_directories("/home/msurov/etc/gcc-arm-none-eabi-7-2017-q4-major/arm-none-eabi/include/c++/7.2.1/")
but it doesn’t seem a good idea.
