LED control using RC contoller
Hi ,
I am working on integration of serial LEDs for certain use case examples like dark environments. I want to turn ON the LEDs manually from RC controller. How can I do it, any help would be appreciated, since I lack the needed expertise on the field.
currenlty using px4 version 1.15v stable.
@rroche @Bunny
What LEDs are you using and where are they connected? Pls add any necessary information along with it.
Sorry for the delayed response, I have not decided with LEDs till now. i want to use the LEDs to be used as flood light for camera. The LEDs is connected to a PWM output. Directly to FC.
If there is any other approach please do share.
If you do not want to control the LEDs then just find the plug and play ones mentioned in px4 docs.
