Irregular behavior of drone in custom simulator
I am currently trying to integrate PX4 in a custom simulator(GitHub - MISTLab/dronela: Open-source simulator for autonomous driving research.) and am having trouble with the behaviour of the drone. I am currently using QGroundControl to send a mission to PX4 and connect with my simulator through a PythonAPI using the TCP port. I am sending GPS and IMU data through Mavlink messages and receiving actuator controls back that I send to the motors. I believe all the transformations were made correctly and the sensor readings are correct. I believe the problem may stem from px4 and the simulator being out of sync somehow. I have the synchronous mode in my simulator set to true as well as applying manual world ticks to make sure they are working together. Currently my drone takes off and then I get an Attitude Failure message from PX4. Would anyone have any recommendations to fix this problem? I’ve pasted my code below. Thanks!
class CarlaIMUData:
    def __init__(self, timestamp=0.0, xmag=0,ymag=0,zmag=0):
        self.timestamp = timestamp
        self.xmag = xmag
        self.ymag = ymag
        self.zmag = zmag
class CarlaGPSData:
    def __init__(self, timestamp=0.0, latitude=0.0, longitude=0.0, altitude=0.0):
        self.latitude = latitude
        self.longitude = longitude
        self.altitude = altitude
import glob
import os
import sys
import time
import math
import pygame
from pymavlink import mavutil
import numpy as np
import random
import math
import matplotlib.pyplot as plt
try:
    sys.path.append(glob.glob('../carla/dist/carla-*%d.%d-%s.egg' % (
        sys.version_info.major,
        sys.version_info.minor,
        'win-amd64' if os.name == 'nt' else 'linux-x86_64'))[0])
except IndexError:
    pass
import carla
import time
gps_data_px4 = None
imu_data_px4 = None
def connect_px4():
    global px4_connection
    print("Waiting to connect...")
    px4_connection = mavutil.mavlink_connection('tcpin:localhost:4560')
    msg = px4_connection.recv_match(blocking = True)
    if msg.get_type() != "COMMAND_LONG":
        raise Exception("error")
    print( "<==", msg)
    if msg.get_type() != "HEARTBEAT":
    print( "<==", msg)
def pressure_at_altitude(h):
    P = ((1.0 - (h / 44330.0)) ** 5.254999) * 101325.0
    # print(" height ", h, " pressure ", P)
    return P +random.uniform(-1,1)
def process_imu_data(data, imu_data_px4):
    if data is not None:
        imu_data_px4.timestamp = int(data.timestamp*1e6) #ticks every fixed delta seconds, becareful when adjusting that value
        imu_data_px4.accelerometer = data.accelerometer
        imu_data_px4.gyroscope = data.gyroscope
        imu_data_px4.xmag = 0.3*math.cos(data.compass+random.uniform(-0.0001,0.0001))
        imu_data_px4.ymag = 0.3*-math.sin(data.compass+random.uniform(-0.0001,0.0001))
        imu_data_px4.zmag = 0.4+random.uniform(-0.0001,0.0001)
        # print("IMU data received:", data)
def process_gps_data(data, gps_data_px4):
        gps_data_px4.timestamp = int(data.timestamp*1e6)
        gps_data_px4.latitude = int(data.latitude * 1e7)
        gps_data_px4.longitude = int(data.longitude * 1e7)
        gps_data_px4.altitude = int(data.altitude*1000)
        # print("GPS data received:", data)
def clamp(value, min_value, max_value):
    return max(min(value, max_value), min_value)
def on_camera_image(image,screen):
    # Get the raw image data
    image_data = image.raw_data
    # Convert the image data to a NumPy array
    image_array = np.frombuffer(image_data, dtype=np.uint8)
    # Reshape the array to match the image dimensions and channels
    image_array = image_array.reshape((image.height, image.width, 4))
    # Extract RGB channels and discard the alpha channel
    rgb_image = image_array[:, :, :3]
    # Correct color channels order
    rgb_image = np.flip(rgb_image, axis=2)
    # Rotate the image 90 degrees counter-clockwise
    rgb_image = np.rot90(rgb_image)
    # Resize the image to match the Pygame window dimensions
    pygame_surface = pygame.surfarray.make_surface(rgb_image)
    pygame_surface = pygame.transform.scale(pygame_surface, (800, 600))
    # Blit the Pygame surface onto the entire screen
    screen.blit(pygame_surface, (0, 0))
    # Update the Pygame display
    pygame.display.flip()
def main():
    pygame.init()
    screen = pygame.display.set_mode((800, 600), pygame.HWSURFACE | pygame.DOUBLEBUF)
    clock = pygame.time.Clock()
    # Connect to the CARLA simulator
    client = carla.Client('localhost', 2000)
    client.set_timeout(10.0)
    # Get the world and set to synchronous mode
    world = client.get_world()
    settings = world.get_settings()
    # settings.no_rendering_mode = True # Don't render
    settings.synchronous_mode = True
    settings.fixed_delta_seconds = 0.05 #PX4 needs messages at atleast 2 Hz # Set the time step for the simulation
    world.apply_settings(settings)
    # Spawn a vehicle named 'lea'
    blueprint_library = world.get_blueprint_library()
    vehicle_bp = blueprint_library.filter('lea')[0]
    spawn_point = carla.Transform(carla.Location(x=0, y=10, z=1), carla.Rotation(yaw=0))
    vehicle = world.spawn_actor(vehicle_bp, spawn_point)
    imu_blueprint = world.get_blueprint_library().find('sensor.other.imu')
    imu_blueprint.set_attribute('noise_accel_stddev_x', '0.0001') #try with no noise
    imu_blueprint.set_attribute('noise_accel_stddev_y', '0.0001')
    imu_blueprint.set_attribute('noise_accel_stddev_z', '0.0001')
    imu_blueprint.set_attribute('noise_gyro_bias_x', '0')
    imu_blueprint.set_attribute('noise_gyro_bias_y', '0')
    imu_blueprint.set_attribute('noise_gyro_bias_z', '0')
    imu_blueprint.set_attribute('noise_gyro_stddev_x', '0.00000001')
    imu_blueprint.set_attribute('noise_gyro_stddev_y', '0.00000001')
    imu_blueprint.set_attribute('noise_gyro_stddev_z', '0.00000001')
    imu_blueprint.set_attribute('sensor_tick', '.005')
    imu_location = carla.Location(x=0, y=0, z=0)
    imu_sensor = world.spawn_actor(imu_blueprint, carla.Transform(imu_location,carla.Rotation(yaw=0)), attach_to=vehicle)
    gps_blueprint = world.get_blueprint_library().find('sensor.other.gnss')
    gps_blueprint.set_attribute('noise_alt_bias', '0.0000001')
    gps_blueprint.set_attribute('noise_alt_stddev', '0.0000001')
    gps_blueprint.set_attribute('noise_lat_bias', '0.0000001')
    gps_blueprint.set_attribute('noise_lat_stddev', '0.0000001')
    gps_blueprint.set_attribute('noise_lon_bias', '0.0000001')
    gps_blueprint.set_attribute('noise_lon_stddev', '0.0000001')
    gps_blueprint.set_attribute('sensor_tick', '.005')
    gps_location = carla.Location(x=0, y=0, z=0)
    gps_sensor = world.spawn_actor(gps_blueprint, carla.Transform(gps_location), attach_to=vehicle)
    imu_data_px4=CarlaIMUData
    gps_data_px4=CarlaGPSData
    gps_sensor.listen(lambda data: process_gps_data(data, gps_data_px4))
    imu_sensor.listen(lambda data: process_imu_data(data, imu_data_px4))
    camera_bp = blueprint_library.find('sensor.camera.rgb')
    camera_transform = carla.Transform(carla.Location(x=-2 ,z=1))
    camera = world.spawn_actor(camera_bp, camera_transform, attach_to=vehicle)
    camera.listen(lambda image: on_camera_image(image,screen))
    init_time=time.time()
    try:
        spectator = world.get_spectator()
        transform = vehicle.get_transform()
        spectator.set_transform(carla.Transform(transform.location + carla.Location(z=2), transform.rotation))
        connect_px4()
        # Main loop
        ready_px4=False
        while True:
            if ready_px4:
                 world.tick()  # Tick the simulation
                 clock.tick()
            spectator.set_transform(carla.Transform(transform.location+carla.Location(x=0) +carla.Location(y=-0) + carla.Location(z=4), carla.Rotation(pitch=-90)))
            if gps_data_px4 is not None and imu_data_px4 is not None:
                time.sleep(settings.fixed_delta_seconds)  # Wait for the next tick
                time_usec           =  int(init_time * 1e6)               # Timestamp (UNIX Epoch time or time since system boot). The receiving end can infer timestamp format (since 1.1.1970 or since system boot) by checking for the magnitude of the number. [us] (type:uint64_t)
                fix_type            = 3                         # 0-1: no fix, 2: 2D fix, 3: 3D fix. Some applications will not use the value of this field unless it is at least two, so always correctly fill in the fix. (type:uint8_t)
                lat                 = gps_data_px4.latitude   # Latitude (WGS84) [degE7] (type:int32_t)
                lon                 = gps_data_px4.longitude        # Longitude (WGS84) [degE7] (type:int32_t)
                alt                 = gps_data_px4.altitude          # Altitude (MSL). Positive for up. [mm] (type:int32_t).
                eph                 = 30       # GPS HDOP horizontal dilution of position (unitless). If unknown, set to: UINT16_MAX (type:uint16_t)
                epv                 = 30      # GPS VDOP vertical dilution of position (unitless). If unknown, set to: UINT16_MAX (type:uint16_t)
                vel                 = 0     # GPS ground speed. If unknown, set to: 65535 [cm/s] (type:uint16_t)
                vn                  = 0      # GPS velocity in north direction in earth-fixed NED frame [cm/s] (type:int16_t)
                ve                  = 0       # GPS velocity in east direction in earth-fixed NED frame [cm/s] (type:int16_t)
                vd                  = 0     # GPS velocity in down direction in earth-fixed NED frame [cm/s] (type:int16_t)
                cog                 = 0      # Course over ground (NOT heading, but direction of movement), 0.0..359.99 degrees. If unknown, set to: 65535 [cdeg] (type:uint16_t)
                satellites_visible  = 255                        # Number of satellites visible. If unknown, set to 255 (type:uint8_t)
                the_id              = 0                         # GPS ID (zero indexed). Used for multiple GPS inputs (type:uint8_t)
                yaw                 = 0                         # Yaw of vehicle relative to Earth's North, zero means not available, use 36000 for north [cdeg] (type:uint16_t)
                if px4_connection != None:
                    px4_connection.mav.hil_gps_send(
                        time_usec           = time_usec             ,
                        fix_type            = fix_type              ,
                        lat                 = lat                   ,
                        lon                 = lon                   ,
                        alt                 = alt                   ,
                        eph                 = eph                   ,
                        epv                 = epv                   ,
                        vel                 = vel                   ,
                        vn                  = vn                    ,
                        ve                  = ve                    ,
                        vd                  = vd                    ,
                        cog                 = cog                   ,
                        satellites_visible  = satellites_visible    ,
                        id                  = the_id                ,
                        yaw                 = yaw                   ,
                xacc                = imu_data_px4.accelerometer.x        # X acceleration [m/s/s] (type:float)
                yacc                = imu_data_px4.accelerometer.y         # Y acceleration [m/s/s] (type:float)
                zacc                = -imu_data_px4.accelerometer.z        # Z acceleration [m/s/s] (type:float)
                xgyro               = imu_data_px4.gyroscope.x       # Angular speed around X axis in body frame [rad/s] (type:float)
                ygyro               = imu_data_px4.gyroscope.y      # Angular speed around Y axis in body frame [rad/s] (type:float)
                zgyro               = -imu_data_px4.gyroscope.z       # Angular speed around Z axis in body frame [rad/s] (type:float)
                xmag                = imu_data_px4.xmag       # X Magnetic field [gauss] (type:float)
                ymag                = imu_data_px4.ymag        # Y Magnetic field [gauss] (type:float)
                zmag                = imu_data_px4.zmag        # Z Magnetic field [gauss] (type:float)
                abs_pressure        = pressure_at_altitude(gps_data_px4.altitude/1000)/100 # Absolute pressure [hPa] (type:float), this is hPa isnt it
                diff_pressure       = 0 # Differential pressure (airspeed) [hPa] (type:float)
                pressure_alt        = gps_data_px4.altitude #/1000    # Altitude calculated from pressure (type:float)
                temperature         = 20  # Temperature [degC] (type:float)
                fields_updated      = 7167                          # Bitmap for fields that have updated since last message, bit 0 = xacc, bit 12: temperature, bit 31: full reset of attitude/position/velocities/etc was performed in sim. (type:uint32_t)
                the_id              = 0                             # Sensor ID (zero indexed). Used for multiple sensor inputs (type:uint8_t)
                    px4_connection.mav.hil_sensor_send(
                        xacc                = xacc              ,
                        yacc                = yacc              ,
                        zacc                = zacc              ,
                        xgyro               = xgyro             ,
                        ygyro               = ygyro             ,
                        zgyro               = zgyro             ,
                        xmag                = xmag              ,
                        ymag                = ymag              ,
                        zmag                = zmag              ,
                        abs_pressure        = abs_pressure      ,
                        diff_pressure       = diff_pressure     ,
                        pressure_alt        = pressure_alt      ,
                        temperature         = temperature       ,
                        fields_updated      = fields_updated    ,
                        id                  = the_id            ,
                    msg = px4_connection.recv_match(blocking = False)
                    if msg != None:
                        print(msg.get_type())
                        if msg.get_type() == 'HIL_ACTUATOR_CONTROLS':
                            ready_px4=True
                            print( "<=", msg.controls[0:4])
                            #fl3-2 fr1-0 rl2-1 rr4-3
                           vehicle.apply_motor_speed(msg.control[2]*2000,msg.controls[0]
                           *2000,msg.controls[1]*2000,msg.controls[3]*2000)
    finally:
        if vehicle is not None:
            imu_sensor.stop()
            imu_sensor.destroy()
            camera.destroy()
            gps_sensor.stop()
            gps_sensor.destroy()
            vehicle.destroy()
            print('Vehicle destroyed.')
        # If something goes wrong, try to disable synchronous mode
        settings.synchronous_mode = False
        print('Synchronous mode disabled.')
if __name__ == '__main__':
    main()
