Okay, I guess I get it working. I had still files of an old version of gradle and also some old fastrtps files which might caused the error. After deleting them I was able with sudo env path=$path_to_gradle6.5 gradle install
to install fastrtps gen.
I followed the installation steps for ROS2 here.
- I have installed ros dashing and melodic.
- Gradle 6.5
- Kotlin: 1.3.72
- Groovy: 2.5.11
- Ant: Apache Ant™ version 1.10.7 compiled on September 1 2019
- JVM: 1.8.0_252 (Private Build 25.252-b09)
- OS: Linux 5.3.0-59-generic amd64
Now I am getting the following error:
[ 76%] Building CXX object CMakeFiles/micrortps_agent.dir/src/micrortps_agent/IridiumsbdStatus_Publisher.cpp.o
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/AdcReport_Publisher.cpp: In member function ‘bool AdcReport_Publisher::init()’:
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/AdcReport_Publisher.cpp:67:25: error: ‘class eprosima::fastrtps::rtps::BuiltinAttributes’ has no member named ‘discovery_config’
PParam.rtps.builtin.discovery_config.leaseDuration = c_TimeInfinite;
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/Airspeed_Publisher.cpp: In member function ‘bool Airspeed_Publisher::init()’:
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/Airspeed_Publisher.cpp:67:25: error: ‘class eprosima::fastrtps::rtps::BuiltinAttributes’ has no member named ‘discovery_config’
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/BatteryStatus_Publisher.cpp: In member function ‘bool BatteryStatus_Publisher::init()’:
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/BatteryStatus_Publisher.cpp:67:25: error: ‘class eprosima::fastrtps::rtps::BuiltinAttributes’ has no member named ‘discovery_config’
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/Cpuload_Publisher.cpp: In member function ‘bool Cpuload_Publisher::init()’:
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/Cpuload_Publisher.cpp:67:25: error: ‘class eprosima::fastrtps::rtps::BuiltinAttributes’ has no member named ‘discovery_config’
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/DistanceSensor_Publisher.cpp: In member function ‘bool DistanceSensor_Publisher::init()’:
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/DistanceSensor_Publisher.cpp:67:25: error: ‘class eprosima::fastrtps::rtps::BuiltinAttributes’ has no member named ‘discovery_config’
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/EstimatorStatus_Publisher.cpp: In member function ‘bool EstimatorStatus_Publisher::init()’:
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/EstimatorStatus_Publisher.cpp:67:25: error: ‘class eprosima::fastrtps::rtps::BuiltinAttributes’ has no member named ‘discovery_config’
CMakeFiles/micrortps_agent.dir/build.make:1619: recipe for target 'CMakeFiles/micrortps_agent.dir/src/micrortps_agent/Airspeed_Publisher.cpp.o' failed
make[2]: *** [CMakeFiles/micrortps_agent.dir/src/micrortps_agent/Airspeed_Publisher.cpp.o] Error 1
make[2]: *** Waiting for unfinished jobs....
CMakeFiles/micrortps_agent.dir/build.make:1606: recipe for target 'CMakeFiles/micrortps_agent.dir/src/micrortps_agent/AdcReport_Publisher.cpp.o' failed
make[2]: *** [CMakeFiles/micrortps_agent.dir/src/micrortps_agent/AdcReport_Publisher.cpp.o] Error 1
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/HomePosition_Publisher.cpp: In member function ‘bool HomePosition_Publisher::init()’:
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/HomePosition_Publisher.cpp:67:25: error: ‘class eprosima::fastrtps::rtps::BuiltinAttributes’ has no member named ‘discovery_config’
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/IridiumsbdStatus_Publisher.cpp: In member function ‘bool IridiumsbdStatus_Publisher::init()’:
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/IridiumsbdStatus_Publisher.cpp:67:25: error: ‘class eprosima::fastrtps::rtps::BuiltinAttributes’ has no member named ‘discovery_config’
make[2]: *** [CMakeFiles/micrortps_agent.dir/src/micrortps_agent/Cpuload_Publisher.cpp.o] Error 1
CMakeFiles/micrortps_agent.dir/build.make:1645: recipe for target 'CMakeFiles/micrortps_agent.dir/src/micrortps_agent/Cpuload_Publisher.cpp.o' failed
CMakeFiles/micrortps_agent.dir/build.make:1632: recipe for target 'CMakeFiles/micrortps_agent.dir/src/micrortps_agent/BatteryStatus_Publisher.cpp.o' failed
make[2]: *** [CMakeFiles/micrortps_agent.dir/src/micrortps_agent/BatteryStatus_Publisher.cpp.o] Error 1
CMakeFiles/micrortps_agent.dir/build.make:1671: recipe for target 'CMakeFiles/micrortps_agent.dir/src/micrortps_agent/EstimatorStatus_Publisher.cpp.o' failed
make[2]: *** [CMakeFiles/micrortps_agent.dir/src/micrortps_agent/EstimatorStatus_Publisher.cpp.o] Error 1
make[2]: *** [CMakeFiles/micrortps_agent.dir/src/micrortps_agent/DistanceSensor_Publisher.cpp.o] Error 1
CMakeFiles/micrortps_agent.dir/build.make:1658: recipe for target 'CMakeFiles/micrortps_agent.dir/src/micrortps_agent/DistanceSensor_Publisher.cpp.o' failed
CMakeFiles/micrortps_agent.dir/build.make:1684: recipe for target 'CMakeFiles/micrortps_agent.dir/src/micrortps_agent/HomePosition_Publisher.cpp.o' failed
make[2]: *** [CMakeFiles/micrortps_agent.dir/src/micrortps_agent/HomePosition_Publisher.cpp.o] Error 1
make[2]: *** [CMakeFiles/micrortps_agent.dir/src/micrortps_agent/IridiumsbdStatus_Publisher.cpp.o] Error 1
CMakeFiles/micrortps_agent.dir/build.make:1697: recipe for target 'CMakeFiles/micrortps_agent.dir/src/micrortps_agent/IridiumsbdStatus_Publisher.cpp.o' failed
make[1]: *** [CMakeFiles/micrortps_agent.dir/all] Error 2
CMakeFiles/Makefile2:158: recipe for target 'CMakeFiles/micrortps_agent.dir/all' failed
make: *** [all] Error 2
Makefile:160: recipe for target 'all' failed
--- stderr: px4_ros_com
openjdk version "1.8.0_252"
OpenJDK Runtime Environment (build 1.8.0_252-8u252-b09-1~18.04-b09)
OpenJDK 64-Bit Server VM (build 25.252-b09, mixed mode)
CMakeFiles/micrortps_agent.dir/build.make:373: warning: overriding recipe for target '/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/Timesync.cpp'
CMakeFiles/micrortps_agent.dir/build.make:202: warning: ignoring old recipe for target '/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/Timesync.cpp'
CMakeFiles/micrortps_agent.dir/build.make:376: warning: overriding recipe for target '/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/TimesyncPubSubTypes.cpp'
CMakeFiles/micrortps_agent.dir/build.make:205: warning: ignoring old recipe for target '/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/TimesyncPubSubTypes.cpp'
CMakeFiles/micrortps_agent.dir/build.make:379: warning: overriding recipe for target '/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/TimesyncPubSubTypes.h'
CMakeFiles/micrortps_agent.dir/build.make:208: warning: ignoring old recipe for target '/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/TimesyncPubSubTypes.h'
/sbin/ldconfig.real: Can't stat /usr/local/lib/x86_64-linux-gnu: No such file or directory
/sbin/ldconfig.real: Path `/usr/local/lib' given more than once
/sbin/ldconfig.real: Path `/lib/x86_64-linux-gnu' given more than once
/sbin/ldconfig.real: Path `/usr/lib/x86_64-linux-gnu' given more than once
/sbin/ldconfig.real: /lib/x86_64-linux-gnu/ld-2.27.so is the dynamic linker, ignoring
/sbin/ldconfig.real: /lib32/ld-2.27.so is the dynamic linker, ignoring
/sbin/ldconfig.real: Can't create temporary cache file /etc/ld.so.cache~: Permission denied
In file included from /home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/RtpsTopics.h:38:0,
from /home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/RtpsTopics.cpp:34:
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/microRTPS_timesync.h: In member function ‘uint64_t TimeSync::setMsgTimestamp(timesync_msg_t*, const uint64_t&)’:
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/microRTPS_timesync.h:170:114: warning: no return statement in function returning non-void [-Wreturn-type]
inline uint64_t setMsgTimestamp(timesync_msg_t* msg, const uint64_t& timestamp) { msg->timestamp() = timestamp; }
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/microRTPS_timesync.h: In member function ‘uint8_t TimeSync::setMsgSysID(timesync_msg_t*, const uint8_t&)’:
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/microRTPS_timesync.h:171:99: warning: no return statement in function returning non-void [-Wreturn-type]
inline uint8_t setMsgSysID(timesync_msg_t* msg, const uint8_t& sys_id) { msg->sys_id() = sys_id; }
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/microRTPS_timesync.h: In member function ‘uint8_t TimeSync::setMsgSeq(timesync_msg_t*, const uint8_t&)’:
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/microRTPS_timesync.h:172:88: warning: no return statement in function returning non-void [-Wreturn-type]
inline uint8_t setMsgSeq(timesync_msg_t* msg, const uint8_t& seq) { msg->seq() = seq; }
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/microRTPS_timesync.h: In member function ‘int64_t TimeSync::setMsgTC1(timesync_msg_t*, const int64_t&)’:
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/microRTPS_timesync.h:173:88: warning: no return statement in function returning non-void [-Wreturn-type]
inline int64_t setMsgTC1(timesync_msg_t* msg, const int64_t& tc1) { msg->tc1() = tc1; }
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/microRTPS_timesync.h: In member function ‘int64_t TimeSync::setMsgTS1(timesync_msg_t*, const int64_t&)’:
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/microRTPS_timesync.h:174:88: warning: no return statement in function returning non-void [-Wreturn-type]
inline int64_t setMsgTS1(timesync_msg_t* msg, const int64_t& ts1) { msg->ts1() = ts1; }
In file included from /home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/microRTPS_timesync.cpp:42:0:
In file included from /home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/RtpsTopics.cpp:34:0:
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/RtpsTopics.h: In member function ‘uint64_t RtpsTopics::setMsgTimestamp(T*, const uint64_t&)’:
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/RtpsTopics.h:175:104: warning: no return statement in function returning non-void [-Wreturn-type]
inline uint64_t setMsgTimestamp(T* msg, const uint64_t& timestamp) { msg->timestamp() = timestamp; }
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/RtpsTopics.h: In member function ‘uint8_t RtpsTopics::setMsgSysID(T*, const uint8_t&)’:
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/RtpsTopics.h:178:89: warning: no return statement in function returning non-void [-Wreturn-type]
inline uint8_t setMsgSysID(T* msg, const uint8_t& sys_id) { msg->sys_id() = sys_id; }
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/RtpsTopics.h: In member function ‘uint8_t RtpsTopics::setMsgSeq(T*, const uint8_t&)’:
/home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/RtpsTopics.h:181:78: warning: no return statement in function returning non-void [-Wreturn-type]
inline uint8_t setMsgSeq(T* msg, const uint8_t& seq) { msg->seq() = seq; }
In file included from /home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/microRTPS_agent.cpp:52:0:
In file included from /home/falke/px4_ros_com_ros2/src/px4_ros_com/src/micrortps_agent/microRTPS_agent.cpp:53:0:
Failed <<< px4_ros_com [ Exited with code 2 ]
Summary: 1 package finished [8min 5s]
1 package failed: px4_ros_com
2 packages had stderr output: px4_msgs px4_ros_com
There seems to be still an error with the mircortps_agent. What can cause this error? Any suggestions? Help?
Thanks!
