Installing PX4 on Ubuntu 24.04 x64 VM
I am trying to get PX4 to run on a 64-bit VM with Ubuntu 24.04. I got some problems running the ubuntu.sh configuration script. I could fix most of them, but I reached an impasse with libncurses5. The newest version of that seems to require an older version of libtinfo6. Here is the specific error I’m getting:
The following packages have unmet dependencies:
libncurses5-dev : Depends: libtinfo6 (= 6.2-Oubuntu2.1) but 6.4+20240113-1ubunt
u2 is to be installed
Depends: libncurses-dev (= 6.2-Oubuntu2.1) but 6.4+20240113-1
ubuntu2 is to be installed
libncursesw5-dev : Depends: libtinfo6 (= 6.2-Oubuntu2.1) but 6.4+20240113-1ubun
1ubuntu2 is to be installed
E: Unable to correct problems, you have held broken packages.
I manually installed the 6.2-0ubuntu2.1 version of libtinfo6, but that didn’t solve the problem.
Should I try on an older version of Ubuntu?
I don’t know whether Ubuntu 24.04 is supported yet. If you use 22.04 it should be fine.
Thanks Julian. I will try v22.004.
Is there any update on Ubuntu 24.04 support?
I created a pull request that uses --break-system-packages to install all Python dependencies as a workaround:
There is also Ubuntu 24.04 Support by MaEtUgR · Pull Request #23126 · PX4/PX4-Autopilot · GitHub that started implementing the switch to Python virtual environments which would be the better way of fixing the installation issues. This doesn’t fully work yet though as far as I’m aware.
