Indipendent flight termination system
Hi, Easa rules says that with >4kg drones in specific scenarios you need a flight termination system independent from the automatic flight control and guidance system, but I haven’t found any pixhawk compatible model. So how to respect this rule?
You can trigger flight termination with a RC switch like this:
Other ways are with a companion computer or through QGC, but you need to implement that yourself.
usually you require two different receiver, one for normal flight controller and other for flight termination.
So you will have two different transmitter also if your transmitter does not support two different receiver.
