Increasing frequency rate controller is run at
Hi all!
I am working on making a fault tolerant controller for PX4 and have modified the rate controller with some additions, but it currently runs at only 250 hz in the SITL simulation and I was wondering if there is any way to increase this speed to 500 hz or 1000 hz. I have tried updating the params IMU_INTEG_RATE and IMU_GYRO_RATEMAX to 1000 each with no avail. I also tried changing the max step size and the real time update rate parameters in the empty.world file in the sitl_gazebo directory and that also didn’t make a change. Does anybody have any idea how I could achieve this?
Best,
Sid
Does anybody have any suggestions for this, any help would be much appreciated!
I’m working exactly on the same problem, any new suggestion? I’ve already tried quite the same mentioned above.
