How to save parameters to flash memory No SD, No EEPROM
I’m playing with a custom board and I’m trying to figure out how to save parameters to the STM32F765 chip flash memory. I looked at the intel/aero board for hints but I must be still doing something wrong. I keep getting various errors when I do a “param save /params” of failed (-6). Is there a list somewhere of what the errors are? Am I trying to write to a valid location? I see the files for /etc are in there like mixers, airframes and such.
Could you share the boot log?
Gladly. Here is the boot from the console log. I’ll also include some other files that may be of use. I’m doing this to a mro pixracerpro board because I know it was working normally before I started messing with the configuration. I’m trying to use it without EEPROM or SD. The custom board doesn’t have those.
Boot output
sercon: Registering CDC/ACM serial driver
sercon: Successfully registered the CDC/ACM serial driver
HW arch: MRO_PIXRACERPRO
FW git-hash: 76141c4d3222f9f4311566d620741240f443e06d
FW version: 1.12.3 0 (17564416)
FW git-branch: feature/remove_sd
OS: NuttX
OS version: Release 8.2.0 (134349055)
OS git-hash: bf660cba2af81f055002b3817c87b1f63a78fd09
Build datetime: Nov 23 2023 16:29:36
Build uri: localhost
Toolchain: GNU GCC, 7.3.1 20180622 (release) [ARM/embedded-7-branch revision 261907]
PX4GUID: 000600000000373934373132511800370047
MCU: STM32H7[4|5]xxx, rev. V
ERROR [param] importing failed (-1)
Board architecture defaults: /etc/init.d/rc.board_arch_defaults
Board defaults: /etc/init.d/rc.board_defaults
Board sensors: /etc/init.d/rc.board_sensors
nsh: bmi088: command not found
bmi085 #0 on SPI bus 5 rotation 8
bmi085 #1 on SPI bus 5 rotation 8
Board extras: /etc/init.d/rc.board_mavlink
INFO  [mavlink] mode: Config, data rate: 800000 B/s on /dev/ttyACM0 @ 57600B
Starting MAVLink on /dev/ttyS1
INFO  [mavlink] mode: Normal, data rate: 1200 B/s on /dev/ttyS1 @ 57600B
No autostart ID found or airframe
Board extras: /etc/init.d/rc.board_extras
NuttShell (NSH) NuttX-11.0.0
nsh> ERROR [parameters] param auto save failed (-6)
defconfig
# This file is autogenerated: PLEASE DO NOT EDIT IT.
# You can use "make menuconfig" to make any modifications to the installed .config file.
# You can then do "make savedefconfig" to generate a new defconfig file that includes your
# modifications.
# CONFIG_DISABLE_ENVIRON is not set
# CONFIG_DISABLE_PSEUDOFS_OPERATIONS is not set
# CONFIG_MMCSD_HAVE_CARDDETECT is not set
# CONFIG_MMCSD_HAVE_WRITEPROTECT is not set
# CONFIG_MMCSD_MMCSUPPORT is not set
# CONFIG_MMCSD_SPI is not set
# CONFIG_NSH_DISABLEBG is not set
# CONFIG_NSH_DISABLESCRIPT is not set
# CONFIG_NSH_DISABLE_DF is not set
# CONFIG_NSH_DISABLE_EXEC is not set
# CONFIG_NSH_DISABLE_EXIT is not set
# CONFIG_NSH_DISABLE_GET is not set
# CONFIG_NSH_DISABLE_ITEF is not set
# CONFIG_NSH_DISABLE_LOOPS is not set
# CONFIG_NSH_DISABLE_SEMICOLON is not set
# CONFIG_NSH_DISABLE_TIME is not set
CONFIG_ARCH="arm"
CONFIG_ARCH_BOARD_CUSTOM=y
CONFIG_ARCH_BOARD_CUSTOM_DIR="../nuttx-config"
CONFIG_ARCH_BOARD_CUSTOM_DIR_RELPATH=y
CONFIG_ARCH_BOARD_CUSTOM_NAME="px4"
CONFIG_ARCH_CHIP="stm32h7"
CONFIG_ARCH_CHIP_STM32H743II=y
CONFIG_ARCH_CHIP_STM32H7=y
CONFIG_ARCH_INTERRUPTSTACK=512
CONFIG_ARCH_STACKDUMP=y
CONFIG_ARMV7M_BASEPRI_WAR=y
CONFIG_ARMV7M_DCACHE=y
CONFIG_ARMV7M_DTCM=y
CONFIG_ARMV7M_ICACHE=y
CONFIG_ARMV7M_MEMCPY=y
CONFIG_ARMV7M_USEBASEPRI=y
CONFIG_BOARDCTL_RESET=y
CONFIG_BOARD_CRASHDUMP=y
CONFIG_BOARD_LOOPSPERMSEC=95150
CONFIG_BOARD_RESET_ON_ASSERT=2
CONFIG_BUILTIN=y
CONFIG_C99_BOOL8=y
CONFIG_CDCACM=y
CONFIG_CDCACM_PRODUCTID=0x1017
CONFIG_CDCACM_PRODUCTSTR="mRoPixracerPro"
CONFIG_CDCACM_RXBUFSIZE=600
CONFIG_CDCACM_TXBUFSIZE=12000
CONFIG_CDCACM_VENDORID=0x26ac
CONFIG_CDCACM_VENDORSTR="mRo"
CONFIG_CLOCK_MONOTONIC=y
CONFIG_DEBUG_FULLOPT=y
CONFIG_DEBUG_HARDFAULT_ALERT=y
CONFIG_DEBUG_SYMBOLS=y
CONFIG_DEFAULT_SMALL=y
CONFIG_DEV_FIFO_SIZE=0
CONFIG_DEV_PIPE_MAXSIZE=1024
CONFIG_DEV_PIPE_SIZE=70
CONFIG_EXPERIMENTAL=y
CONFIG_FAT_DMAMEMORY=y
CONFIG_FAT_LCNAMES=y
CONFIG_FAT_LFN=y
CONFIG_FAT_LFN_ALIAS_HASH=y
CONFIG_FDCLONE_STDIO=y
CONFIG_FS_BINFS=y
CONFIG_FS_CROMFS=y
CONFIG_FS_FAT=y
CONFIG_FS_FATTIME=y
CONFIG_FS_PROCFS=y
CONFIG_FS_PROCFS_INCLUDE_PROGMEM=y
CONFIG_FS_PROCFS_REGISTER=y
CONFIG_FS_ROMFS=y
CONFIG_GRAN=y
CONFIG_GRAN_INTR=y
CONFIG_HAVE_CXX=y
CONFIG_HAVE_CXXINITIALIZE=y
CONFIG_I2C=y
CONFIG_I2C_RESET=y
CONFIG_IDLETHREAD_STACKSIZE=750
CONFIG_LIBC_FLOATINGPOINT=y
CONFIG_LIBC_LONG_LONG=y
CONFIG_LIBC_STRERROR=y
CONFIG_MAX_TASKS=64
CONFIG_MEMSET_64BIT=y
CONFIG_MEMSET_OPTSPEED=y
CONFIG_MMCSD=n
CONFIG_MMCSD_SDIO=n
CONFIG_MMCSD_SDIOWAIT_WRCOMPLETE=n
CONFIG_MM_REGIONS=4
CONFIG_MTD=y
CONFIG_MTD_BYTE_WRITE=y
CONFIG_MTD_PARTITION=y
CONFIG_MTD_PROGMEM=y
CONFIG_MTD_RAMTRON=y
CONFIG_NAME_MAX=40
CONFIG_NFILE_DESCRIPTORS=12
CONFIG_NSH_ARCHINIT=y
CONFIG_NSH_ARCHROMFS=y
CONFIG_NSH_ARGCAT=y
CONFIG_NSH_BUILTIN_APPS=y
CONFIG_NSH_CMDPARMS=y
CONFIG_NSH_CROMFSETC=y
CONFIG_NSH_DISABLE_IFCONFIG=y
CONFIG_NSH_DISABLE_IFUPDOWN=y
CONFIG_NSH_DISABLE_MB=y
CONFIG_NSH_DISABLE_MH=y
CONFIG_NSH_DISABLE_MW=y
CONFIG_NSH_DISABLE_TELNETD=y
CONFIG_NSH_LINELEN=128
CONFIG_NSH_MAXARGUMENTS=15
CONFIG_NSH_NESTDEPTH=8
CONFIG_NSH_QUOTE=y
CONFIG_NSH_ROMFSETC=y
CONFIG_NSH_ROMFSSECTSIZE=128
CONFIG_NSH_STRERROR=y
CONFIG_NSH_VARS=y
CONFIG_OTG_ID_GPIO_DISABLE=y
CONFIG_PIPES=y
CONFIG_PREALLOC_TIMERS=50
CONFIG_PRIORITY_INHERITANCE=y
CONFIG_PTHREAD_MUTEX_ROBUST=y
CONFIG_PTHREAD_STACK_MIN=512
CONFIG_RAMTRON_SETSPEED=y
CONFIG_RAMTRON_WRITEWAIT=y
CONFIG_RAM_SIZE=245760
CONFIG_RAM_START=0x20010000
CONFIG_RAW_BINARY=y
CONFIG_READLINE_CMD_HISTORY=y
CONFIG_READLINE_TABCOMPLETION=y
CONFIG_RTC_DATETIME=y
CONFIG_SCHED_ATEXIT=y
CONFIG_SCHED_HPWORK=y
CONFIG_SCHED_HPWORKPRIORITY=249
CONFIG_SCHED_HPWORKSTACKSIZE=1280
CONFIG_SCHED_INSTRUMENTATION=y
CONFIG_SCHED_INSTRUMENTATION_EXTERNAL=y
CONFIG_SCHED_LPWORK=y
CONFIG_SCHED_LPWORKPRIORITY=50
CONFIG_SCHED_LPWORKSTACKSIZE=1632
CONFIG_SCHED_WAITPID=y
CONFIG_SDCLONE_DISABLE=y
CONFIG_SDMMC1_SDIO_PULLUP=n
CONFIG_SEM_NNESTPRIO=8
CONFIG_SEM_PREALLOCHOLDERS=0
CONFIG_SERIAL_IFLOWCONTROL_WATERMARKS=y
CONFIG_SERIAL_TERMIOS=y
CONFIG_SIG_DEFAULT=y
CONFIG_SIG_SIGALRM_ACTION=y
CONFIG_SIG_SIGUSR1_ACTION=y
CONFIG_SIG_SIGUSR2_ACTION=y
CONFIG_SIG_SIGWORK=4
CONFIG_STACK_COLORATION=y
CONFIG_START_DAY=30
CONFIG_START_MONTH=11
CONFIG_STDIO_BUFFER_SIZE=256
CONFIG_STM32H7_ADC1=y
CONFIG_STM32H7_ADC3=y
CONFIG_STM32H7_BBSRAM=y
CONFIG_STM32H7_BBSRAM_FILES=5
CONFIG_STM32H7_BDMA=y
CONFIG_STM32H7_BKPSRAM=y
CONFIG_STM32H7_DMA1=y
CONFIG_STM32H7_DMA2=y
CONFIG_STM32H7_DMACAPABLE=y
CONFIG_STM32H7_FLOWCONTROL_BROKEN=y
CONFIG_STM32H7_I2C1=y
CONFIG_STM32H7_I2C_DYNTIMEO=y
CONFIG_STM32H7_I2C_DYNTIMEO_STARTSTOP=10
CONFIG_STM32H7_OTGFS=y
CONFIG_STM32H7_PROGMEM=y
CONFIG_STM32H7_RTC=y
CONFIG_STM32H7_RTC_HSECLOCK=y
CONFIG_STM32H7_RTC_MAGIC_REG=1
CONFIG_STM32H7_SAVE_CRASHDUMP=y
CONFIG_STM32H7_SDMMC1=n
CONFIG_STM32H7_SERIALBRK_BSDCOMPAT=y
CONFIG_STM32H7_SERIAL_DISABLE_REORDERING=y
CONFIG_STM32H7_SPI1=y
CONFIG_STM32H7_SPI1_DMA=y
CONFIG_STM32H7_SPI1_DMA_BUFFER=1024
CONFIG_STM32H7_SPI2=y
CONFIG_STM32H7_SPI5=y
CONFIG_STM32H7_SPI5_DMA=y
CONFIG_STM32H7_SPI5_DMA_BUFFER=1024
CONFIG_STM32H7_SPI6=y
CONFIG_STM32H7_SPI6_DMA=y
CONFIG_STM32H7_SPI6_DMA_BUFFER=1024
CONFIG_STM32H7_SPI_DMA=y
CONFIG_STM32H7_SPI_DMATHRESHOLD=8
CONFIG_STM32H7_TIM1=y
CONFIG_STM32H7_TIM3=y
CONFIG_STM32H7_TIM4=y
CONFIG_STM32H7_UART4=y
CONFIG_STM32H7_UART7=y
CONFIG_STM32H7_UART8=y
CONFIG_STM32H7_USART1=y
CONFIG_STM32H7_USART2=y
CONFIG_STM32H7_USART3=y
CONFIG_STM32H7_USART6=y
CONFIG_STM32H7_USART_BREAKS=y
CONFIG_STM32H7_USART_INVERT=y
CONFIG_STM32H7_USART_SINGLEWIRE=y
CONFIG_STM32H7_USART_SWAP=y
CONFIG_SYSTEM_CDCACM=y
CONFIG_SYSTEM_NSH=y
CONFIG_TASK_NAME_SIZE=24
CONFIG_TTY_SIGINT=y
CONFIG_TTY_SIGSTP=y
CONFIG_UART4_BAUD=57600
CONFIG_UART4_RXBUFSIZE=600
CONFIG_UART4_TXBUFSIZE=1500
CONFIG_UART7_BAUD=57600
CONFIG_UART7_RXBUFSIZE=600
CONFIG_UART7_SERIAL_CONSOLE=y
CONFIG_UART7_TXBUFSIZE=1500
CONFIG_UART8_BAUD=57600
CONFIG_UART8_RXBUFSIZE=600
CONFIG_UART8_TXBUFSIZE=1500
CONFIG_USART2_BAUD=57600
CONFIG_USART2_IFLOWCONTROL=y
CONFIG_USART2_OFLOWCONTROL=y
CONFIG_USART2_RXBUFSIZE=600
CONFIG_USART2_TXBUFSIZE=1500
CONFIG_USART3_BAUD=57600
CONFIG_USART3_IFLOWCONTROL=y
CONFIG_USART3_OFLOWCONTROL=y
CONFIG_USART3_RXBUFSIZE=600
CONFIG_USART3_TXBUFSIZE=3000
CONFIG_USART6_BAUD=57600
CONFIG_USART6_RXBUFSIZE=600
CONFIG_USBDEV=y
CONFIG_USBDEV_BUSPOWERED=y
CONFIG_USBDEV_MAXPOWER=500
CONFIG_USEC_PER_TICK=1000
CONFIG_USERMAIN_STACKSIZE=2944
CONFIG_USER_ENTRYPOINT="nsh_main"
CONFIG_WATCHDOG=y
CONFIG_STM32_FLASH_CONFIG_I=y
CONFIG_STM32_FLASH_WORKAROUND_DATA_CACHE_CORRUPTION_ON_RWW=y
script.ld
 * scripts/script.ld
 *   Copyright (C) 2020 Gregory Nutt. All rights reserved.
 *   Author: Gregory Nutt <gnutt@nuttx.org>
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * 1. Redistributions of source code must retain the above copyright
 *    notice, this list of conditions and the following disclaimer.
 * 2. Redistributions in binary form must reproduce the above copyright
 *    notice, this list of conditions and the following disclaimer in
 *    the documentation and/or other materials provided with the
 *    distribution.
 * 3. Neither the name NuttX nor the names of its contributors may be
 *    used to endorse or promote products derived from this software
 *    without specific prior written permission.
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
 * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
 * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
 * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
 * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
 * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
 * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
 * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
 * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
 * ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
 * POSSIBILITY OF SUCH DAMAGE.
/* The board uses an STM32H743II has 2048Kb of main FLASH memory.
 * The flash memory is partitioned into a User Flash memory and a System
 * Flash memory. Each of these memories has two banks:
 *   1) User Flash memory:
 *      Bank 1: Start address 0x0800:0000 to 0x080F:FFFF with 8 sectors, 128Kb each
 *      Bank 2: Start address 0x0810:0000 to 0x081F:FFFF with 8 sectors, 128Kb each
 *   2) System Flash memory:
 *      Bank 1: Start address 0x1FF0:0000 to 0x1FF1:FFFF with 1 x 128Kb sector
 *      Bank 1: Start address 0x1FF4:0000 to 0x1FF5:FFFF with 1 x 128Kb sector
 *   3) User option bytes for user configuration, only in Bank 1.
 * In the STM32H743II, two different boot spaces can be selected through
 * the BOOT pin and the boot base address programmed in the BOOT_ADD0 and
 * BOOT_ADD1 option bytes:
 *   1) BOOT=0: Boot address defined by user option byte BOOT_ADD0[15:0].
 *      ST programmed value: Flash memory at 0x0800:0000
 *   2) BOOT=1: Boot address defined by user option byte BOOT_ADD1[15:0].
 *      ST programmed value: System bootloader at 0x1FF0:0000
 * There's a switch on board, the BOOT0 pin is at ground so by default,
 * the STM32 will boot to address 0x0800:0000 in FLASH unless the switch is
 * drepresed, then the boot will be from 0x1FF0:0000
 * The STM32H743ZI also has 1024Kb of data SRAM.
 * SRAM is split up into several blocks and into three power domains:
 *   1) TCM SRAMs are dedicated to the Cortex-M7 and are accessible with
 *      0 wait states by the Cortex-M7 and by MDMA through AHBS slave bus
 *      1.1) 128Kb of DTCM-RAM beginning at address 0x2000:0000
 *           The DTCM-RAM is organized as 2 x 64Kb DTCM-RAMs on 2 x 32 bit
 *           DTCM ports. The DTCM-RAM could be used for critical real-time
 *           data, such as interrupt service routines or stack / heap memory.
 *           Both DTCM-RAMs can be used in parallel (for load/store operations)
 *           thanks to the Cortex-M7 dual issue capability.
 *      1.2)  64Kb of ITCM-RAM beginning at address 0x0000:0000
 *           This RAM is connected to ITCM 64-bit interface designed for
 *           execution of critical real-times routines by the CPU.
 *   2) AXI SRAM (D1 domain) accessible by all system masters except BDMA
 *      through D1 domain AXI bus matrix
 *      2.1) 512Kb of SRAM beginning at address 0x2400:0000
 *   3) AHB SRAM (D2 domain) accessible by all system masters except BDMA
 *      through D2 domain AHB bus matrix
 *      3.1) 128Kb of SRAM1 beginning at address 0x3000:0000
 *      3.2) 128Kb of SRAM2 beginning at address 0x3002:0000
 *      3.3)  32Kb of SRAM3 beginning at address 0x3004:0000
 *      SRAM1 - SRAM3 are one contiguous block: 288Kb at address 0x3000:0000
 *   4) AHB SRAM (D3 domain) accessible by most of system masters
 *      through D3 domain AHB bus matrix
 *      4.1)  64Kb of SRAM4 beginning at address 0x3800:0000
 *      4.1)   4Kb of backup RAM beginning at address 0x3880:0000
 * When booting from FLASH, FLASH memory is aliased to address 0x0000:0000
 * where the code expects to begin execution by jumping to the entry point in
 * the 0x0800:0000 address range.
MEMORY
	ITCM_RAM  (rwx) : ORIGIN = 0x00000000, LENGTH =   64K
	FLASH      (rx) : ORIGIN = 0x08020000, LENGTH = 1920K
	DTCM1_RAM (rwx) : ORIGIN = 0x20000000, LENGTH =   64K
	DTCM2_RAM (rwx) : ORIGIN = 0x20010000, LENGTH =   64K
	AXI_SRAM  (rwx) : ORIGIN = 0x24000000, LENGTH =  512K /* D1 domain AXI bus */
	SRAM1     (rwx) : ORIGIN = 0x30000000, LENGTH =  128K /* D2 domain AHB bus */
	SRAM2     (rwx) : ORIGIN = 0x30020000, LENGTH =  128K /* D2 domain AHB bus */
	SRAM3     (rwx) : ORIGIN = 0x30040000, LENGTH =   32K /* D2 domain AHB bus */
	SRAM4     (rwx) : ORIGIN = 0x38000000, LENGTH =   64K /* D3 domain */
	BKPRAM    (rwx) : ORIGIN = 0x38800000, LENGTH =    4K
OUTPUT_ARCH(arm)
EXTERN(_vectors)
ENTRY(_stext)
 * Ensure that abort() is present in the final object.  The exception handling
 * code pulled in by libgcc.a requires it (and that code cannot be easily avoided).
EXTERN(abort)
EXTERN(_bootdelay_signature)
SECTIONS
	.text : {
		_stext = ABSOLUTE(.);
		*(.vectors)
		. = ALIGN(32);
		This signature provides the bootloader with a way to delay booting
		_bootdelay_signature = ABSOLUTE(.);
		FILL(0xffecc2925d7d05c5)
		. += 8;
		*(.text .text.*)
		*(.fixup)
		*(.gnu.warning)
		*(.rodata .rodata.*)
		*(.gnu.linkonce.t.*)
		*(.glue_7)
		*(.glue_7t)
		*(.got)
		*(.gcc_except_table)
		*(.gnu.linkonce.r.*)
		_etext = ABSOLUTE(.);
	} > FLASH
	 * Init functions (static constructors and the like)
	.init_section : {
		_sinit = ABSOLUTE(.);
		KEEP(*(.init_array .init_array.*))
		_einit = ABSOLUTE(.);
	} > FLASH
	__param ALIGN(4): {
		__param_start = ABSOLUTE(.);
		KEEP(*(__param*))
		__param_end = ABSOLUTE(.);
	} > flash
	.ARM.extab : {
		*(.ARM.extab*)
	} > FLASH
	__exidx_start = ABSOLUTE(.);
	.ARM.exidx : {
		*(.ARM.exidx*)
	} > FLASH
	__exidx_end = ABSOLUTE(.);
	_eronly = ABSOLUTE(.);
	.data : {
		_sdata = ABSOLUTE(.);
		*(.data .data.*)
		*(.gnu.linkonce.d.*)
		CONSTRUCTORS
		_edata = ABSOLUTE(.);
	} > AXI_SRAM AT > FLASH
	.bss : {
		_sbss = ABSOLUTE(.);
		*(.bss .bss.*)
		*(.gnu.linkonce.b.*)
		*(COMMON)
		. = ALIGN(4);
		_ebss = ABSOLUTE(.);
	} > AXI_SRAM
	/* Emit the the D3 power domain section for locating BDMA data */
	.sram4_reserve (NOLOAD) :
		*(.sram4)
		. = ALIGN(4);
		_sram4_heap_start = ABSOLUTE(.);
	} > SRAM4
	/* Stabs debugging sections. */
	.stab 0 : { *(.stab) }
	.stabstr 0 : { *(.stabstr) }
	.stab.excl 0 : { *(.stab.excl) }
	.stab.exclstr 0 : { *(.stab.exclstr) }
	.stab.index 0 : { *(.stab.index) }
	.stab.indexstr 0 : { *(.stab.indexstr) }
	.comment 0 : { *(.comment) }
	.debug_abbrev 0 : { *(.debug_abbrev) }
	.debug_info 0 : { *(.debug_info) }
	.debug_line 0 : { *(.debug_line) }
	.debug_pubnames 0 : { *(.debug_pubnames) }
	.debug_aranges 0 : { *(.debug_aranges) }
And I added
#define FLASH_BASED_PARAMS
to the board_config.h file
I may also need more room for parameters. How do I get that? I’m assuming it is in the script.ld file
You also need to add the flash initialization code into your init.c file
#if defined(FLASH_BASED_PARAMS)
	static sector_descriptor_t params_sector_map[] = {
		{15, 128 * 1024, 0x081E0000},
		{0, 0, 0},
	/* Initialize the flashfs layer to use heap allocated memory */
	int result = parameter_flashfs_init(params_sector_map, NULL, 0);
	if (result != OK) {
		syslog(LOG_ERR, "[boot] FAILED to init params in FLASH %d\n", result);
		led_on(LED_AMBER);
#endif // FLASH_BASED_PARAMS
and add the flashfs.h include to the init.c file
# if defined(FLASH_BASED_PARAMS)
#  include <parameters/flashparams/flashfs.h>
#endif
