Hi! I am trying to read vehicle_odometry from the PX4 (SITL) over the ROS2 bridge. I have made all the edits I know of but the VehicleOdometry publisher is never “matched” when the microRTPS agent is started. What is going wrong?
I am using the updated PX4-Autopilot/px4_ros_com/px4_msgs repositories from microRTPS: more fixes and improvements #18052.
Here was my setup:
- write a
vehicle_odometry_listener.cppmodeled aftersensor_combined_listener.cppin the px4_ros_com examples directory - add
vehicle_odometry_listenerto “custom executables” inCMakeLists.txt - check
urtps_bridge_topics.yamlon the PX4-Autopilot side, confirm- msg: vehicle_odometryis set tosend: true. - run the
uorb_to_ros_urtps_topics.pyscript to duplicate topic information on the px4_ros_com side - clean the px4_ros_com workspace via
clean_all.bash - build the px4_ros_com workspace via
build_ros2_workspace.bash - clean and make the PX4:
make px4_sitl_rtps jmavsim(micrortps_client is automatically started) - start the microRTPS agent:
micrortps_agent -t UDP
The agent starts up and I can confirm that both Sensor Combined and Vehicle Odometry are listed as Publishers. Then, I run: ros2 run px4_ros_com vehicle_odometry_listener and nothing happens. The VehicleOdometer Publisher is never “matched”. How can I make this happen?
In contrast - I can do this with SensorCombined: ros2 run px4_ros_com sensor_combined_listener and 1) the SensorCombined publisher is matched (see below), and 2) the data is printed to the console. Here is the output when I start the microRTPS agent:
---- Publishers ----
- Timesync publishers started
- TrajectoryWaypoint publisher started
- VehicleControlMode publisher started
- VehicleOdometry publisher started
- VehicleStatus publisher started
- CollisionConstraints publisher started
- TimesyncStatus publisher started
- SensorCombined publisher started
- VehicleTrajectoryWaypointDesired publisher started
[ micrortps_agent ] SensorCombined publisher matched
[ micrortps_agent ] SensorCombined publisher unmatched
Thanks for your help.
