Herelink controller stick inputs as mavlink messages
I posted this question on the herelink discussion forum, but no replies so far. So I’m trying my luck here.
I’m playing around with a setup where I have a orange cube with a companion computer connected to a wifi network. This works great and I can control it via a computer and mission planner.
I would like to use my herelink controller in the same setup, basically skipping the herelink air unit. When connecting the controller to the same network, it connects just fine and gets telemetry. I can even enable the on-screen stick inputs in QGC to control the quad.
However, I cannot seem to find a way to use the physical sticks on the controller. Is there a way to get these stick inputs to be sent as mavlink messages over wifi?
Since you’re bypassing the Herelink air unit and connecting the controller directly via Wi-Fi, the physical stick inputs aren’t sent as MAVLink messages by default. The stick data normally goes through the air unit, so without it, the controller doesn’t transmit them.
One workaround could be connecting the Herelink to your companion computer as a joystick (via USB or Bluetooth) and using something like mavproxy or joy2mav to send MANUAL_CONTROL messages. Just keep in mind latency and safety/failsafe handling if you’re flying like this.
