Pls help me resolve this error
Looks like there is something wrong with your gazebo setup.
Are you running inside a virtual machine? Can you run gazebo without px4? If not, you need to fix your problem with gazebo before you try and make it work with px4
Are you sure you are running https://github.com/PX4/PX4-Autopilot ?
The model you are showing doesn’t exist in the public repository
Hi…Gazebo simply begins the scene without yielding anything to the terminal. I likewise had a go at adding the code expected to turn the joint, as in sync 5, with a similar outcome. I even had a go at eliminating the module library record (libvelodyne_plugin.so) that I constructed through and through, while as yet having the line
