Hi,I download the last version if PX4 fireware,
there is fatal err when I builded ,How can I do to fix this problem?
FAILED: cd /home/kwong/Downloads/PX4-Autopilot/build/px4_fmu-v2_default/NuttX/nuttx && make --quiet --no-print-directory CONFIG_ARCH_BOARD_CUSTOM=y pass1dep > nuttx_context.log
fatal: Not a git repository: --absolute-git-dir
Hi @elviskuang! Welcome to the community,…
Normally this means you were not in a directory that is a git repo when you tried to run a git command.
Did you download the zip or clone the repo?
Hi @jimdgit! I also have the same problem that @elviskuang had… Personally, I cloned the repo from git, as the guide suggests. Could it be a problem related to the installed git version? I have the 2.7.4 version and it seems to be the already upgraded version (in Linux 16.04)…
