Example for communication between pixhawk and companion computer using MAVROS
Is there any example for interfacing a raspberry pi3 and pixhawk using the MAVROS protocol. I’m currently working on a example such as taking pictures and sending the pic info to pixhawk only when needed. I don’t want an offboard control , need only a way to transmit and receive some info from pixhawk.
Any leads would be appreciated. Thanks
@nikesh_elango Here is an example: http://dev.px4.io/master/en/ros/mavros_offboard.html
Thanks for the info, i installed ROS/Gazebo for px4 as per the instructions in https://dev.px4.io/master/en/setup/dev_env_linux_ubuntu.html#rosgazebo
And i got an error during installation
Unable to locate package ros-melodic-desktop-full
I’m using ubuntu 20.04 OS.
@nikesh_elango ros melodic is not supported in 20.04
@Jaeyoung-Lim i reverted my OS back to 18.04. Still getting some problems as below
Failed     << mavlink:make                         [ Exited with code 2 ]
Failed    <<< mavlink                              [ 0.3 seconds ]
Abandoned <<< libmavconn                           [ Unrelated job failed ]
Abandoned <<< mavros                               [ Unrelated job failed ]
Abandoned <<< mavros_extras                        [ Unrelated job failed ]
Abandoned <<< test_mavros                          [ Unrelated job failed ]
_______________________________________________________________________________
>Errors     << mavros_msgs:cmake /home/okulo/catkin_ws/logs/mavros_msgs/build.cmake.000.log
CMake Error at /opt/ros/melodic/share/catkin/cmake/catkinConfig.cmake:83 (find_package):
  Could not find a package configuration file provided by "geographic_msgs"
  with any of the following names:
    geographic_msgsConfig.cmake
    geographic_msgs-config.cmake
 Add the installation prefix of "geographic_msgs" to CMAKE_PREFIX_PATH or
  set "geographic_msgs_DIR" to a directory containing one of the above files.
  If "geographic_msgs" provides a separate development package or SDK, be
  sure it has been installed.
  CMakeLists.txt:4 (find_package)
cd /home/okulo/catkin_ws/build/mavros_msgs; catkin build --get-env mavros_msgs | catkin env -si  /usr/bin/cmake /home/okulo/catkin_ws/src/mavros/mavros_msgs --no-warn-unused-cli -DCATKIN_DEVEL_PREFIX=/home/okulo/catkin_ws/devel/.private/mavros_msgs -DCMAKE_INSTALL_PREFIX=/home/okulo/catkin_ws/install; cd -
Failed     << mavros_msgs:cmake                    [ Exited with code 1 ]
Failed    <<< mavros_msgs                          [ 2.3 seconds ]
[build] Summary: 1 of 7 packages succeeded.
[build]   Ignored:   None.
[build]   Warnings:  None.
[build]   Abandoned: 4 packages were abandoned.
[build]   Failed:    2 packages failed.
[build] Runtime: 4.8 seconds total.
[build] Note: Workspace packages have changed, please re-source setup files to use them.
Is this normal? should i install some other packages?
@nikesh_elango Have you tried looking at the installation instructions for mavros? https://github.com/mavlink/mavros/blob/master/mavros/README.md#installation
@Jaeyoung-Lim Thanks for the info, I tried the binary installation of MAVROS. The mavlink and mavros packages were installed successfully.But the mavros_extras were not installed.
[build] Found ‘6’ packages in 0.0 seconds.
[build] Package table is up to date.
Starting >>> mavlink
Starting >>> mavros_msgs
Finished <<< mavros_msgs [ 0.9 seconds ]
Finished <<< mavlink [ 1.1 seconds ]
Starting >>> libmavconn
Finished <<< libmavconn [ 0.2 seconds ]
Starting >>> mavros
Finished <<< mavros [ 0.7 seconds ]
Starting >>> mavros_extras
Errors << mavros_extras:make /home/okulo/catkin_ws/logs/mavros_extras/build.make.002.log
/home/okulo/catkin_ws/src/mavros/mavros_extras/src/plugins/odom.cpp: In member function ‘void mavros::extra_plugins::OdometryPlugin::odom_cb(const ConstPtr&)’:
/home/okulo/catkin_ws/src/mavros/mavros_extras/src/plugins/odom.cpp:228:53: error: ‘BODY_FRD’ is not a member of ‘mavlink::common::MAV_FRAME’
msg.child_frame_id = utils::enum_value(MAV_FRAME::BODY_FRD);
make[2]: *** [CMakeFiles/mavros_extras.dir/src/plugins/odom.cpp.o] Error 1
make[1]: *** [CMakeFiles/mavros_extras.dir/all] Error 2
make: *** [all] Error 2
cd /home/okulo/catkin_ws/build/mavros_extras; catkin build --get-env mavros_extras | catkin env -si /usr/bin/make --jobserver-fds=6,7 -j; cd -
Failed << mavros_extras:make [ Exited with code 2 ]
Failed <<< mavros_extras [ 7.3 seconds ]
[build] Summary: 4 of 6 packages succeeded.
[build] Abandoned: 1 packages were abandoned.
[build] Failed: 1 packages failed.
[build] Runtime: 9.4 seconds total.
I encountered some problems while installing ,I had to update some python packages.
The above issue is solved :-https://github.com/mavlink/mavros/issues/1424
