I’m getting the following errors while simulating px4 using gazebo simulator on ubuntu 18.04 linux.
I followed the instructions from here: [Linux · PX4 Developer Guide]
Please let me know the solution for this issue.
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
GSTREAMER_LIBRARIES (ADVANCED)
linked by target “gazebo_vision_plugin” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “gazebo_uuv_plugin” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “gazebo_lidar_plugin” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “gazebo_geotagged_images_plugin” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “gazebo_controller_interface” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “sensor_msgs” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “gazebo_sonar_plugin” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “gazebo_opticalflow_plugin” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “std_msgs” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “gazebo_imu_plugin” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “gazebo_opticalflow_mockup_plugin” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “mav_msgs” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “nav_msgs” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “gazebo_wind_plugin” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “physics_msgs” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “gazebo_gimbal_controller_plugin” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “gazebo_mavlink_interface” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “gazebo_motor_model” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “gazebo_catapult_plugin” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “gazebo_multirotor_base_plugin” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “gazebo_magnetometer_plugin” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “gazebo_barometer_plugin” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “gazebo_gst_camera_plugin” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “gazebo_irlock_plugin” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “gazebo_gps_plugin” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “gazebo_video_stream_widget” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
linked by target “LiftDragPlugin” in directory /home/unicita/src/Firmware/Tools/sitl_gazebo
– Configuring incomplete, errors occurred!
See also “/home/unicita/src/Firmware/build/px4_sitl_default/build_gazebo/CMakeFiles/CMakeOutput.log”.
See also “/home/unicita/src/Firmware/build/px4_sitl_default/build_gazebo/CMakeFiles/CMakeError.log”.
FAILED: external/Stamp/sitl_gazebo/sitl_gazebo-configure
cd /home/unicita/src/Firmware/build/px4_sitl_default/build_gazebo && /usr/bin/cmake -DCMAKE_INSTALL_PREFIX=/usr/local -DSEND_VISION_ESTIMATION_DATA=ON -GNinja /home/unicita/src/Firmware/Tools/sitl_gazebo && /usr/bin/cmake -E touch /home/unicita/src/Firmware/build/px4_sitl_default/external/Stamp/sitl_gazebo/sitl_gazebo-configure
Makefile:205: recipe for target ‘px4_sitl’ failed
make: *** [px4_sitl] Error 1
Thank you.
