Running the following command:
HEADLESS=1 make px4_sitl gazebo_solo
and I get the following errors:
______ __ __ ___
| ___ \ \ \ / / / |
| |_/ / \ V / / /| |
| __/ / \ / /_| |
| | / /^\ \ \___ |
\_| \/ \/ |_/
px4 starting.
INFO [dataman] Unknown restart, data manager file './dataman' size is 11405132 bytes
INFO [simulator] Waiting for initial data on UDP port 14560. Please start the flight simulator to proceed..
Gazebo multi-robot simulator, version 9.5.0
Copyright (C) 2012 Open Source Robotics Foundation.
http://gazebosim.org
[Msg] Waiting for master.
[Msg] Publicized address: 10.0.1.39
[Err] [Plugin.hh:180] Failed to load plugin /Users/dlw/src/Firmware/build/px4_sitl_default/build_gazebo/libgazebo_multirotor_base_plugin.dylib: dlopen(/Users/dlw/src/Firmware/build/px4_sitl_default/build_gazebo/libgazebo_multirotor_base_plugin.dylib, 9): Library not loaded: /usr/local/opt/glog/lib/libglog.0.3.5.dylib
Referenced from: /usr/local/opt/opencv/lib/libopencv_sfm.3.4.dylib
Reason: image not found
[Err] [Plugin.hh:180] Failed to load plugin /Users/dlw/src/Firmware/build/px4_sitl_default/build_gazebo/libgazebo_motor_model.dylib: dlopen(/Users/dlw/src/Firmware/build/px4_sitl_default/build_gazebo/libgazebo_motor_model.dylib, 9): Library not loaded: /usr/local/opt/glog/lib/libglog.0.3.5.dylib
[Err] [Plugin.hh:180] Failed to load plugin /Users/dlw/src/Firmware/build/px4_sitl_default/build_gazebo/libgazebo_gps_plugin.dylib: dlopen(/Users/dlw/src/Firmware/build/px4_sitl_default/build_gazebo/libgazebo_gps_plugin.dylib, 9): Library not loaded: /usr/local/opt/glog/lib/libglog.0.3.5.dylib
[Err] [Plugin.hh:180] Failed to load plugin /Users/dlw/src/Firmware/build/px4_sitl_default/build_gazebo/libgazebo_mavlink_interface.dylib: dlopen(/Users/dlw/src/Firmware/build/px4_sitl_default/build_gazebo/libgazebo_mavlink_interface.dylib, 9): Library not loaded: /usr/local/opt/glog/lib/libglog.0.3.5.dylib
[Err] [Plugin.hh:180] Failed to load plugin /Users/dlw/src/Firmware/build/px4_sitl_default/build_gazebo/libgazebo_imu_plugin.dylib: dlopen(/Users/dlw/src/Firmware/build/px4_sitl_default/build_gazebo/libgazebo_imu_plugin.dylib, 9): Library not loaded: /usr/local/opt/glog/lib/libglog.0.3.5.dylib
