Error on JmavSim window11
My environment is window 11
(Windows 개발 환경 | PX4 오토파일럿 사용자 설명서 (v1.12)) i do as this document tell
but i have a problem on toolchain i guess?
here is my error code
$ make px4_sitl jmavsim
[1/2] launching px4 jmavsim_iris (SYS_AUTOSTART=10017)
ERROR [px4_work_queue] setting sched params for wq:lp_default failed (134)
| ___ \ \ \ / / / |
| |/ / \ V / / /| |
| __/ / \ / /
| | / /^\ \ ___ |
_| / / |_/
px4 starting.
INFO [px4] startup script: /bin/sh etc/init.d-posix/rcS 0
env SYS_AUTOSTART: 10017
INFO [param] selected parameter default file parameters.bson
INFO [param] selected parameter backup file parameters_backup.bson
SYS_AUTOCONFIG: curr: 0 → new: 1
SYS_AUTOSTART: curr: 0 → new: 10017
CAL_ACC0_ID: curr: 0 → new: 1310988
CAL_GYRO0_ID: curr: 0 → new: 1310988
CAL_ACC1_ID: curr: 0 → new: 1310996
CAL_GYRO1_ID: curr: 0 → new: 1310996
CAL_ACC2_ID: curr: 0 → new: 1311004
CAL_GYRO2_ID: curr: 0 → new: 1311004
CAL_MAG0_ID: curr: 0 → new: 197388
CAL_MAG0_PRIO: curr: -1 → new: 50
CAL_MAG1_ID: curr: 0 → new: 197644
CAL_MAG1_PRIO: curr: -1 → new: 50
SENS_BOARD_X_OFF: curr: 0.0000 → new: 0.0000
SENS_DPRES_OFF: curr: 0.0000 → new: 0.0010
INFO [dataman] data manager file ‘./dataman’ size is 7866664 bytes
/cygdrive/c/PX4/home/PX4-Autopilot/build/px4_sitl_default/rootfs/etc/init.d-posix/px4-rc.simulator: line 39: [: : integer expression expected
INFO [init] jMAVSim simulator
Error: could not open `C:\PX4\toolchain\jdk\lib\amd64\jvm.cfg’
INFO [simulator_mavlink] using TCP on remote host localhost port 4560
WARN [simulator_mavlink] Please ensure port 4560 is not blocked by a firewall.
INFO [simulator_mavlink] Resolved host ‘localhost’ to address: 127.0.0.1
INFO [simulator_mavlink] Waiting for simulator to accept connection on TCP port 4560
Buildfile: C:\PX4\home\PX4-Autopilot\Tools\simulation\jmavsim\jMAVSim\build.xml
make_dirs:
compile:
create_run_jar:
[jar] Building jar: C:\PX4\home\PX4-Autopilot\Tools\simulation\jmavsim\jMAVSim\out\production\jmavsim_run.jar
copy_res:
BUILD SUCCESSFUL
Total time: 1 second
Checked this? scala - Running Java gives "Error: could not open `C:\Program Files\Java\jre6\lib\amd64\jvm.cfg'" - Stack Overflow
