Good evening,
I’m not able to launch the sitl simulation as suggested here. When I execute the command make px4_sitl jmavsim I get the following error:
[1/2] launching px4 jmavsim_iris (SYS_AUTOSTART=10017)
______ __ __ ___
| ___ \ \ \ / / / |
| |_/ / \ V / / /| |
| __/ / \ / /_| |
| | / /^\ \ \___ |
\_| \/ \/ |_/
px4 starting.
INFO [px4] startup script: /bin/sh etc/init.d-posix/rcS 0
env SYS_AUTOSTART: 10017
INFO [param] selected parameter default file parameters.bson
INFO [param] selected parameter backup file parameters_backup.bson
SYS_AUTOCONFIG: curr: 0 -> new: 1
SYS_AUTOSTART: curr: 0 -> new: 10017
CAL_ACC0_ID: curr: 0 -> new: 1310988
CAL_GYRO0_ID: curr: 0 -> new: 1310988
CAL_ACC1_ID: curr: 0 -> new: 1310996
CAL_GYRO1_ID: curr: 0 -> new: 1310996
CAL_ACC2_ID: curr: 0 -> new: 1311004
CAL_GYRO2_ID: curr: 0 -> new: 1311004
CAL_MAG0_ID: curr: 0 -> new: 197388
CAL_MAG0_PRIO: curr: -1 -> new: 50
CAL_MAG1_ID: curr: 0 -> new: 197644
CAL_MAG1_PRIO: curr: -1 -> new: 50
SENS_BOARD_X_OFF: curr: 0.0000 -> new: 0.0000
SENS_DPRES_OFF: curr: 0.0000 -> new: 0.0010
INFO [dataman] data manager file './dataman' size is 7866664 bytes
etc/init.d-posix/rcS: 39: [: Illegal number:
INFO [init] jMAVSim simulator
INFO [simulator_mavlink] using TCP on remote host localhost port 4560
WARN [simulator_mavlink] Please ensure port 4560 is not blocked by a firewall.
INFO [simulator_mavlink] Resolved host 'localhost' to address: 127.0.0.1
INFO [simulator_mavlink] Waiting for simulator to accept connection on TCP port 4560
Buildfile: /home/paolo/PX4-Autopilot/Tools/simulation/jmavsim/jMAVSim/build.xml
make_dirs:
compile:
create_run_jar:
copy_res:
BUILD SUCCESSFUL
Total time: 0 seconds
Options parsed, starting Sim.
Starting GUI...
Exception in thread "main" java.lang.reflect.InvocationTargetException
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at org.eclipse.jdt.internal.jarinjarloader.JarRsrcLoader.main(JarRsrcLoader.java:61)
Caused by: java.lang.InternalError: XXX0 profile[2]: GL2 -> profileImpl GL3bc !!! not mapped
at com.jogamp.opengl.GLProfile.computeProfileMap(GLProfile.java:2098)
at com.jogamp.opengl.GLProfile.initProfilesForDeviceCritical(GLProfile.java:1976)
at com.jogamp.opengl.GLProfile.initProfilesForDevice(GLProfile.java:1895)
at com.jogamp.opengl.GLProfile.initProfilesForDefaultDevices(GLProfile.java:1861)
at com.jogamp.opengl.GLProfile.access$000(GLProfile.java:80)
at com.jogamp.opengl.GLProfile$1.run(GLProfile.java:239)
at java.base/java.security.AccessController.doPrivileged(AccessController.java:318)
at com.jogamp.opengl.GLProfile.initSingleton(GLProfile.java:225)
at com.jogamp.opengl.GLProfile.getProfileMap(GLProfile.java:2324)
at com.jogamp.opengl.GLProfile.get(GLProfile.java:1042)
at com.jogamp.opengl.GLProfile.get(GLProfile.java:1071)
at com.jogamp.opengl.GLProfile.getMaxFixedFunc(GLProfile.java:824)
at javax.media.j3d.JoglPipeline.initialize(JoglPipeline.java:131)
at javax.media.j3d.Pipeline.createPipeline(Pipeline.java:92)
at javax.media.j3d.MasterControl.loadLibraries(MasterControl.java:858)
at javax.media.j3d.VirtualUniverse.<clinit>(VirtualUniverse.java:267)
at me.drton.jmavsim.Visualizer3D.<init>(Visualizer3D.java:194)
at me.drton.jmavsim.Simulator.<init>(Simulator.java:193)
at me.drton.jmavsim.Simulator.main(Simulator.java:944)
... 5 more
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007ff8a968b611, pid=9020, tid=9053
# JRE version: OpenJDK Runtime Environment (17.0.7+7) (build 17.0.7+7-Ubuntu-0ubuntu120.04)
# Java VM: OpenJDK 64-Bit Server VM (17.0.7+7-Ubuntu-0ubuntu120.04, mixed mode, sharing, tiered, compressed oops, compressed class ptrs, g1 gc, linux-amd64)
# Problematic frame:
# C [libnvwgf2umx.so+0x1a47611]
# No core dump will be written. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# /home/paolo/PX4-Autopilot/Tools/simulation/jmavsim/jMAVSim/out/production/hs_err_pid9020.log
I’m using Windows 11 with WSL. I followed all the steps showed in the documentation.
How can I fix this? Thanks in advance.
