EKF2 not intializing on fresh hardware, gets fixed after sensor calibration parameter factory reset
Background
I’ve noticed that with certain sensor calibration parameters, the EKF2 just fails to initialize & provide attitude estimates.
It would either:
  1. Not initialize at all, and there would be no local pose data (velocity, position, attitude)
  2. Initialize, but have erratic attitude and pose data (diverging position, completely wrong attitude)
Example log: Flight Review
Sensor Calibration Parameters Reset
This issue disappears indeed when the sensor calibration data is reset (as reported in a post linked below as well).
When I did the reset, it also then allowed EKF2 to initialize correctly, and when I do the diff of parameters, it comes out like this (Left is before reset, Right is after reset):
File comparison  : before_reset.txt | after_reset.txt
Component 1-1:
CAL_ACC0_XOFF    : -0.314           | 0.00975
CAL_ACC0_XSCALE  : 1.06             | 1
CAL_ACC0_YOFF    : -0.614           | -0.00372
CAL_ACC0_YSCALE  : 1.01             | 1
CAL_ACC0_ZOFF    : 2.63             | -0.018
CAL_ACC0_ZSCALE  : 1.47             | 1
CAL_ACC1_XOFF    : -0.0503          | -0.000126
CAL_ACC1_XSCALE  : 1.08             | 1
CAL_ACC1_YOFF    : -0.672           | 0.00871
CAL_ACC1_YSCALE  : 1.03             | 1
CAL_ACC1_ZOFF    : 2.36             | -0.121
CAL_ACC1_ZSCALE  : 1.51             | 1
CAL_GYRO0_XOFF   : 0                | -0.00197
CAL_GYRO0_YOFF   : 0                | -0.00372
CAL_GYRO0_ZOFF   : 0                | -0.00245
CAL_GYRO1_XOFF   : 0.00332          | 0.00269
CAL_GYRO1_ZOFF   : 0.0232           | 0.0157
CAL_GYRO2_ID     : 1310988          | 0
CAL_GYRO2_PRIO   : 50               > X
CAL_GYRO2_ROT    : -1               > X
CAL_GYRO2_XOFF   : 0.000103         > X
CAL_GYRO2_YOFF   : 0.000054         > X
CAL_GYRO2_ZOFF   : 0.000063         > X
CAL_MAG0_ID      : 0                | 396321
CAL_MAG0_PRIO    : -1               | 50
CAL_MAG0_XOFF    : 0                | 0.028
CAL_MAG0_YOFF    : 0                | -0.0573
CAL_MAG0_ZOFF    : 0                | -0.0387
CAL_MAG_COMP_TYP : X                < 0
CAL_MAG_SIDES    : X                < 63
COM_FLIGHT_UUID  : 8                | 9
LND_FLIGHT_T_LO  : 154845050        | 174930794
SENS_BOARD_X_OFF : 0                | -1.18
SENS_BOARD_Y_OFF : 0                | -0.124
SENS_MAG_AUTOCAL : X                < 1
SENS_MAG_AUTOROT : X                < 1
SENS_MAG_SIDES   : X                < 63
SYS_HAS_MAG      : 0                | 1
38 parameters differ
One of the big differences are definitely the accelerometer offset values, which seemed to have messed up the EKF2.
Question
I am wondering how tolerant EKF2 is to such bad calibration data (since even before doing the reset, it seemed like sensor_accel data contained sane output, around 9.8 m/s^2, as in the log linked above), regarding it’s initialization & pose estimation.
Would it make sense to have some kind of alert mechanism to notify user in case the calibration seems off, if that’s detectable? @bresch
How did you end up with such a bad accel calibration? The z scale is 1.47, which is insanely high.
Maybe we should make the accel calibration fail if the scale is above a certain threshold (maybe > 1.1, that’s already quite large).
