The following is a summary of the Dronecode Messaging Working Group from 2. March 2017
eProsima gave an update on the current status of FastRTPS to uORB bridge.
Previously, eProsima had a Proof-of-Concept which consisted of a bridge that published a topic from a Pixracer to FastRTPS on a Raspberry Pi. The Pixracer and the Raspberry Pi communicated via UART.
It has now been generalized to publish any uORB message, generating code from a .msg file, in a similar fashion to ROS2.
Current status:
- Only publishes from uORB to FastRTPS, the other way will be implemented soon
- Dynamic memory allocation is required when serializing, can be changed later
- Some minor compilation problems, should be solved next week
eProsima are also working on a FastRTPS to ROS2 bridge, which will allow communication with ROS. That is, ROS <-> ROS2 <-> FastRTPS <-> uORB. There were some questions about the speed of the pipeline, but it is believed to be fast enough.
Code will be uploaded to github soon.
