Features and benefits
• Modular parts
o Easy-to-replace powertrain. No more soldering hassles.
• Fully assembled and ready-to-fly
o Avoid the headache and uncertainty of building a drone from scratch. Draco-R is fully assembled, tested, and ready to fly, right out of the box.
• Integrated Jetson TX2 (or Nano)
o Auvidea J120 carrier board
o Draco-R’s flight controller is tightly integrated with the Jetson onboard computer.
• Powerful powertrain
o Inherits the speed of the award-winning Draco racing drone, Draco-R easily reaches speeds of over 100km/h
• Smart battery
o The SMBUS-based battery provides you with detailed information without calibrating the current sensor, unlike with most drone batteries
• Payload mount bay
o Draco-R gives you a mounting plate for a wide variety of payloads
• RTK-GNSS ready
o Draco-R can be equipped with RTK-GNSS (optional)
• Computer vision ready
o Draco-R is tested with most Intel RealSense products including VIO-based indoor navigation and obstacle avoidance.
• Hot swap between desktop and field
o Keep implementing your ideas without interruption! Draco-R supports hot swap and online battery charging while you run a companion computer on your desktop
I am curious on what this means? Does this mean there is a way to trasnfer the configuration of the jetson on the Draco-R to the desktop?
Hi Jaeyoung, Thank you for your question. Yes, you are correct. You can transfer the configuration on the Jetson on the Draco-R to your desktop.
@CommodoreSpaceCat Can you explain how this is done? Also the link for the product is missing…
Do anyone have the documentation for this drone? Or is it possible to get the website working again?
