Hello everyone, I hope you are doing well. Could you please tell me how I can send information to the Ardupilot PX4 flight controller, such as the number of satellites or coordinates, by spoofing the GPS data.
And here is an example of my code.
import time
import logging
from pymavlink import mavutil
import random
# Set up logging
logging.basicConfig(level=logging.DEBUG)
def send_gps_raw_int(master, time_usec, fix_type, lat, lon, alt, eph, epv, vel, cog, satellites):
logging.debug(f"Preparing to send GPS_RAW_INT with the following parameters: "
f"time_usec={time_usec}, fix_type={fix_type}, lat={lat}, lon={lon}, alt={alt}, "
f"eph={eph}, epv={epv}, vel={vel}, cog={cog}, satellites={satellites}")
# Send GPS_RAW_INT message
master.mav.gps_raw_int_send(
time_usec, # UNIX time in microseconds
fix_type, # GPS fix type (0: no fix, 1: 2D fix, 2: 3D fix)
lat, # Latitude (WGS84), in degrees * 1E7
lon, # Longitude (WGS84), in degrees * 1E7
alt, # Altitude (AMSL, not WGS84), in meters * 1000 (positive for up)
eph, # GPS HDOP horizontal dilution of position in cm (unknown if 65535)
epv, # GPS VDOP vertical dilution of position in cm (unknown if 65535)
vel, # GPS ground speed (m/s * 100). If unknown, set to 65535
cog, # Course over ground (degrees * 100). If unknown, set to 65535
satellites # Number of satellites visible. If unknown, set to 255
message = master.recv_match(type='GPS_RAW_INT', timeout=1)
if message:
logging.info(f"Message sent and received back: "
f"time_usec={message.time_usec}, fix_type={message.fix_type}, lat={message.lat}, "
f"lon={message.lon}, alt={message.alt}, eph={message.eph}, epv={message.epv}, "
f"vel={message.vel}, cog={message.cog}, satellites_visible={message.satellites_visible}")
else:
logging.warning("Message sent but no response received")
def receive_gps_raw_int(client):
msg = client.recv_match(type='GPS_RAW_INT', blocking=True)
if msg:
logging.info(f"Received GPS_RAW_INT: "
f"time_usec={msg.time_usec}, fix_type={msg.fix_type}, lat={msg.lat}, lon={msg.lon}, "
f"alt={msg.alt}, eph={msg.eph}, epv={msg.epv}, vel={msg.vel}, cog={msg.cog}, "
f"satellites_visible={msg.satellites_visible}")
return msg
def main():
master = mavutil.mavlink_connection('/dev/ttyAMA0', baud=115200)
logging.info("Connected to MAVLink through /dev/ttyAMA0")
# Wait for the autopilot to send a heartbeat signal
master.wait_heartbeat()
logging.info("Heartbeat received from autopilot")
# GPS_RAW_INT parameters
fix_type = 3
lat = 377749000 # Latitude in degrees * 1E7
lon = -1224194000 # Longitude in degrees * 1E7
alt = 1657484 # Altitude in meters * 1000
eph = 10 # Horizontal dilution of precision
epv = 10 # Vertical dilution of precision
vel = 0 # Speed
cog = 0 # Course over ground
while True:
# Time in microseconds
time_usec = int(time.time() * 1e6)
# Generate a random number of satellites between 5 and 55
satellites = random.randint(5, 55)
logging.debug(f"Generated satellites count: {satellites}")
# Check received message
receive_gps_raw_int(master)
# Wait before sending the next message
time.sleep(2.0) # Increased interval for testing
if __name__ == "__main__":
main()
