Hi
I am developing a module that will subscribe to the attitude setpoint, store between 20 and 100 values and use them to calculate a new attitude setpoint that will get published on a different topic (I haven’t done the publishing part yet) Once the buffer is filled, it goes back to the first value and overwrites it with a new one. I start the application through the nsh console.
My code seems to run fine while on a SITL simulation with jMAVsim. I uploaded it to a pixracer and connected to the console through the USB port in the pixracer. However, when I try to run my application, the connection dies and then I cannot connect to the pixracer even if I turn it on and off. I have to unplug it for a couple of minutes and try again.
I have no idea what could be the problem. I do need my application to run at a high rate, so I don’t know if that could be causing problems. Should I add a sleep command inside the while loop? How short does this sleep period need to be? How big can I make my buffer considering it is an array of attitude setpoint structures?
Here is my code:
static bool thread_should_exit = false; /< daemon exit flag */
static bool thread_running = false; /< daemon status flag */
static int _control_task; /**< Handle of daemon task / thread */
- daemon management function.
__EXPORT int att_command_proc_main(int argc, char *argv[]);
- Mainloop of daemon.
int att_command_proc_thread_main(int argc, char *argv[]);
- Print the correct usage.
static void usage(const char *reason);
static void
if (reason) {
warnx("%s\n", reason);
warnx("usage: att_command_proc {start|stop|status} [-p <additional params>]\n\n");
The daemon app only briefly exists to start
the background job. The stack size assigned in the
Makefile does only apply to this management task.
The actual stack size should be set in the call
to task_create().
if (argc < 2) {
usage(“missing command”);
return 1;
}if (!strcmp(argv[1], “start”)) {
if (thread_running) { warnx("daemon already running\n"); /* this is not an error */ return 0; } thread_should_exit = false; _control_task = px4_task_spawn_cmd("att_command_proc", SCHED_DEFAULT, SCHED_PRIORITY_DEFAULT, 2000, att_command_proc_thread_main, (argv) ? (char *const *)&argv[2] : (char *const *)NULL); return 0;}
if (!strcmp(argv[1], “stop”)) {
thread_should_exit = true;
return 0;
}if (!strcmp(argv[1], “status”)) {
warnx("\trunning\n");} else { warnx("\tnot started\n"); } return 0;}
usage(“unrecognized command”);
return 1;
warnx("[daemon] starting\n");
thread_running = true;
/*Variable declarations*/
int _v_att_sp_sub = orb_subscribe(ORB_ID(vehicle_attitude_setpoint)); //subscribe to attitude setpoint
orb_set_interval(_v_att_sp_sub,20); //update every 20 ms
bool updated;
static uint64_t last_sample_time = 0; //Initialize time in microseconds
float dt=(hrt_absolute_time()-last_sample_time)/1000000.0f;
float samplingInterval = 0.05f;
struct vehicle_attitude_setpoint_s _v_att_sp;
/*Initialize buffer*/
int bufferSize=20;
struct vehicle_attitude_setpoint_s _v_att_sp_proc_buffer[bufferSize];
memset(&_v_att_sp_proc_buffer,0,sizeof(_v_att_sp_proc_buffer));
int procIndex =0;
/*Initialize attitude setpoint to publish*/
struct vehicle_attitude_setpoint_s _v_att_sp_proc;
memset(&_v_att_sp_proc,0,sizeof(_v_att_sp_proc));
/*Initialize processing parameters*/
double A1=0,A2=0,t2=0;
double K,tau;
/*Calculate processing*/
K=1;
tau=0.1;
A1=1/(1+K);
A2=K/(1+K);
t2=tau/2;
int count = 0;
while (!thread_should_exit) {
orb_check(_v_att_sp_sub,&updated);
if(updated){
orb_copy(ORB_ID(vehicle_attitude_setpoint),_v_att_sp_sub,&_v_att_sp);
if (dt>=samplingInterval){
_v_att_sp_proc_buffer[procIndex].roll_body=_v_att_sp_proc_buffer[procIndex].roll_body+_v_att_sp.roll_body*(float)A1;
_v_att_sp_proc_buffer[(procIndex+(int)(t2/(double)samplingInterval))%(bufferSize-1)].roll_body=_v_att_sp.roll_body*(float)A2;
_v_att_sp_proc=_v_att_sp_proc_buffer[procIndex];
memset(&_v_att_sp_proc_buffer[procIndex],0,sizeof(_v_att_sp_proc_buffer[procIndex]));
if(procIndex+1<bufferSize-1)
procIndex++;
else
procIndex=0;
last_sample_time = hrt_absolute_time();
//Print processed value to screen
count++;
if (count == 4){
count = 0;
PX4_INFO("Roll: %f\tprocRoll: %f",(double)_v_att_sp.roll_body,(double)_v_att_sp_proc.roll_body);
warnx("[daemon] exiting.\n");
return 0;
