Hey guys I really need help with my hexacopter…
The problem is that it won’t even take off properly. I tried to fly the drone the other day, but shortly after takeoff, about 5cm above the ground, it tilted sharply to the right and kind of flipped over itself, like a clockwise sideways flip. During takeoff, it moved itself back and forth a bit.
The problem is that I can’t explain why at all.
The Pre Arm Check was problem free, it had around 10 satellites and high accuracy. I took off at full throttle in Position mode, thinking that this is where the drone controls itself best, or should I have started in Altitude?
The ground was a dirt road and there was a light breeze (around 10 kmh). I haven’t set the PID values of the drone itself yet, as many from tutorials set it while flying.
I’m also not sure if the center of gravity in the setup as I flew is maybe too high due to the battery on top (but actually the same battery is down again).
Or is there something wrong with the general setup?
Setup:
Frame Turnigy 680 Pro
13" Carbon Wings
Motor Turnigy 4108 380kv
ESC 40A Hobbywing
PX4
Akku Floureon 6S 6200mah 40C
2x Lidar nach Unten und Vorne
Weight : arround 3.5kg now, later: 5.5kg
Thanks for any help
