Hi I am trying to trigger a servo through Aux out of Cube Black controller. The servo rail is powered through BEC. I have set RC_map_AUX1 to Channel 10. I am using Q X7 Taranis and have set the Channel 10 and programmed corresponding switch which appears to be working fine on the Taranis as I move the switch but nothing happens on the quad. If I manually turn the servo and power on the drone, at initialization I can see the servo move and center, so I know current is passing through and servo connection is correct. But why am I not able to control it through the RC transmitter?
Thanks for the help.
