I want to connect the SC16IS752 chip [here] via the I2C A
or I2C B
port on the PixHawk 4. The goal is to connect multiple (at least 2) independent UART devices.
To do so, I wrote a driver, based on the [pca9685] driver. Based on the [datasheet of the chip] and this [example code], I modified the code as shown below.
Now the problem is, I cannot connect to the board, all I get is the return code -125
. I tried with the original I2C address of the chip (0x90
) as well as the right shifted (0x48
) adress, as some sources suggest. The chip/board itself is working, I verified it with a spare Raspberry Pi.
Is there anything I missed to get the connection working? Do I have to specifiy the I2C port on the PixHawk? If so, how would I do this? Or do I have to add some information about the chip somewhere else for the I2C connection to work?
Any help is appreciated!
* Copyright (c) 2012-2017 PX4 Development Team. All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* 1. Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in
* the documentation and/or other materials provided with the
* distribution.
* 3. Neither the name PX4 nor the names of its contributors may be
* used to endorse or promote products derived from this software
* without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
* ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
* POSSIBILITY OF SUCH DAMAGE.
* @file sc16is752.cpp
* Driver for the SC16IS752 I2C PWM module
* The chip is used on the Adafruit I2C/PWM converter https://www.adafruit.com/product/815
* Parts of the code are adapted from the arduino library for the board
* https://github.com/adafruit/Adafruit-PWM-Servo-Driver-Library
* for the license of these parts see the
* arduino_Adafruit_PWM_Servo_Driver_Library_license.txt file
* see https://github.com/adafruit/Adafruit-PWM-Servo-Driver-Library for contributors
* @author Thomas Gubler <thomasgubler@gmail.com>
#include <px4_config.h>
#include <px4_defines.h>
#include <drivers/device/i2c.h>
#include <sys/types.h>
#include <stdint.h>
#include <string.h>
#include <stdlib.h>
#include <stdbool.h>
#include <fcntl.h>
#include <unistd.h>
#include <stdio.h>
#include <ctype.h>
#include <math.h>
#include <px4_getopt.h>
#include <nuttx/wqueue.h>
#include <nuttx/clock.h>
#include <perf/perf_counter.h>
#include <systemlib/err.h>
#include <uORB/uORB.h>
#include <uORB/topics/i2c_readout.h>
#include <board_config.h>
#include <drivers/drv_io_expander.h>
#define ADDR 0x90 // I2C adress
#define SC16IS752_DEVICE_PATH "/dev/sc16is752"
#define SC16IS752_BUS PX4_I2C_BUS_EXPANSION
#define RHR 0x00 // Recv Holding Register is 0x00 in READ Mode
#define THR 0x00 // Xmit Holding Register is 0x00 in WRITE Mode
#define IER 0x01 // Interrupt Enable Register
#define IIR 0x02 // Interrupt Identification Register in READ Mode
#define FCR 0x02 // FIFO Control Register in WRITE Mode
#define LCR 0x03 // Line Control Register
#define MCR 0x04 // Modem Control Register
#define LSR 0x05 // Line status Register
#define MSR 0x06 // Modem Status Register
#define SPR 0x07 // ScratchPad Register
#define TCR 0x06 // Transmission Control Register
#define TLR 0x07 // Trigger Level Register
#define TXLVL 0x08 // Xmit FIFO Level Register
#define RXLVL 0x09 // Recv FIFO Level Register
#define IODir 0x0A // I/O Pins Direction Register
#define IOState 0x0B // I/O Pins State Register
#define IOIntEna 0x0C // I/O Interrupt Enable Register
#define IOControl 0x0E // I/O Pins Control Register
#define EFCR 0x0F // Extra Features Control Register
#define DLL 0x00 // Divisor Latch LSB 0x00
#define DLH 0x01 // Divisor Latch MSB 0x01
#define EFR 0x02 // Enhanced Function Register
#define I2CWRITE 0x00
#define I2CREAD 0x01
#define CHANA 0
#define CHANB 1
/* interface ioctls */
#define IOCTL_RESET 1
#define IOCTL_MEASURE 2
typedef begin_packed_struct struct SC16IS752_data_t {
union {
uint8_t chan_a;
uint8_t chan_b;
} uart;
} end_packed_struct SC16IS752_data_t;
class SC16IS752 : public device::I2C
public:
SC16IS752(int bus = SC16IS752_BUS, uint8_t address = ADDR);
virtual ~SC16IS752() = default;
virtual int init();
virtual int ioctl(struct file *filp, int cmd, unsigned long arg);
virtual int info();
virtual int reset();
bool is_running() { return _running; }
private:
work_s _work;
enum IOX_MODE _mode;
bool _running;
int _i2ciox_interval;
bool _should_run;
perf_counter_t _comms_errors;
uint8_t _msg[3];
orb_advert_t _i2c_readout_topic;
int _orb_class_instance;
struct i2c_readout_s _i2c_readout;
SC16IS752_data_t reading;
bool _mode_on_initialized; /** Set to true after the first call of i2ciox in mode IOX_MODE_ON */
static void i2ciox_trampoline(void *arg);
void i2ciox();
/* Wrapper to read a byte from addr */
int _read(uint8_t reg, uint8_t chan, uint8_t &value);
/* Wrapper to wite a byte to addr */
int _write(uint8_t reg, uint8_t chan, uint8_t value);
/* for now, we only support one board */
namespace
SC16IS752 *g_sc16is752;
void sc16is752_usage();
extern "C" __EXPORT int sc16is752_main(int argc, char *argv[]);
SC16IS752::SC16IS752(int bus, uint8_t address) :
I2C("sc16is752", SC16IS752_DEVICE_PATH, bus, address, 100000),
_mode(IOX_MODE_OFF),
_running(false),
_i2ciox_interval(SEC2TICK(1.0f / 60.0f)),
_should_run(false),
_comms_errors(perf_alloc(PC_COUNT, "sc16is752_com_err")),
_i2c_readout_topic(nullptr),
_orb_class_instance(-1),
_mode_on_initialized(false)
memset(&_work, 0, sizeof(_work));
memset(_msg, 0, sizeof(_msg));
int
SC16IS752::init()
int ret;
I2C::init();
* This routine initializes Channels A and B
* Copyright (c) 2008 Dave Yeatman
* https://www.ccsinfo.com/forum/viewtopic.php?t=36523
// Channel A Setups
//Prescaler in MCR defaults on MCU reset to the value of 1
_write(LCR, CHANA, 0x80); // 0x80 to program baud rate divisor
_write(DLL, CHANA, 0x18); // 0x18=9600K, 0x06 =38,42K with X1=3.6864MHz
_write(DLH, CHANA, 0x00); //
_write(LCR, CHANA, 0xBF); // access EFR register
_write(EFR, CHANA, 0X10); // enable enhanced registers
_write(LCR, CHANA, 0x03); // 8 data bits, 1 stop bit, no parity
_write(FCR, CHANA, 0x07); // reset TXFIFO, reset RXFIFO, enable FIFO mode
// Channel B Setups
_write(LCR, CHANB, 0x80); // 0x80 to program baud rate divisor
_write(DLL, CHANB, 0x18); // 0x18=9600K, 0x06 =38,42K with X1=3.6864MHz
_write(DLH, CHANB, 0x00); //
_write(LCR, CHANB, 0xBF); // access EFR register
_write(EFR, CHANB, 0X10); // enable enhanced registers
_write(LCR, CHANB, 0x03); // 8 data bits, 1 stop bit, no parity
_write(FCR, CHANB, 0x07); // reset TXFIFO, reset RXFIFO, enable FIFO mode
// Test connection
uint8_t test_buf = 0x00;
ret = _read(RHR, CHANA, test_buf);
if (ret != OK) {
return ret;
ret = reset();
if (ret != OK) {
return ret;
return ret;
int
SC16IS752::ioctl(struct file *filp, int cmd, unsigned long arg)
int ret = -EINVAL;
switch (cmd) {
case IOX_SET_MODE:
if (_mode != (IOX_MODE)arg) {
switch ((IOX_MODE)arg) {
case IOX_MODE_OFF:
warnx("shutting down");
break;
case IOX_MODE_ON:
warnx("starting");
break;
case IOX_MODE_TEST_OUT:
warnx("test starting");
break;
default:
return -1;
_mode = (IOX_MODE)arg;
// if not active, kick it
if (!_running) {
_running = true;
work_queue(LPWORK, &_work, (worker_t)&SC16IS752::i2ciox_trampoline, this, 1);
return OK;
default:
// see if the parent class can make any use of it
ret = CDev::ioctl(filp, cmd, arg);
break;
return ret;
int
SC16IS752::info()
int ret = OK;
if (is_running()) {
warnx("Driver is running, mode: %u", _mode);
} else {
warnx("Driver started but not running");
return ret;
void
SC16IS752::i2ciox_trampoline(void *arg)
SC16IS752 *i2ciox = reinterpret_cast<SC16IS752 *>(arg);
i2ciox->i2ciox();
* Main loop function
void
SC16IS752::i2ciox()
PX4_INFO("I'M ALIVE!");
if (_mode == IOX_MODE_TEST_OUT) {
_should_run = true;
} else if (_mode == IOX_MODE_OFF) {
_should_run = false;
} else {
if (!_mode_on_initialized) {
/* Subscribe to actuator control 2 (payload group for gimbal) */
_i2c_readout_topic = orb_advertise(ORB_ID(i2c_readout), &_i2c_readout);
_mode_on_initialized = true;
uint8_t buf;
uint8_t status;
* Read from Channel A
buf = 0x00;
status = 0;
status = _read(LSR, CHANA, buf);
PX4_INFO("Chan A status: %u", status);
PX4_INFO("Chan A buf: %u", buf);
if ((status > 0)) { // && (buf & 0x01)) { // is data waiting?
// data present in receiver FIFO
status = _read(RHR, CHANA, buf);
reading.uart.chan_a = buf;
PX4_INFO("Buf: %u, Status: %u", buf, status);
* Read from Channel B
buf = 0x00;
status = 0;
status = _read(LSR, CHANB, buf);
PX4_INFO("Chan B status: %u", status);
PX4_INFO("Chan B buf: %u", buf);
status = _read(RHR, CHANB, buf);
reading.uart.chan_b = buf;
_i2c_readout.channel_a = reading.uart.chan_a;
_i2c_readout.channel_b = reading.uart.chan_b;
/* publish it */
if (_i2c_readout_topic != nullptr) {
/* publish it */
orb_publish(ORB_ID(i2c_readout), _i2c_readout_topic, &_i2c_readout);
_should_run = true;
// check if any activity remains, else stop
if (!_should_run) {
_running = false;
return;
// re-queue ourselves to run again later
_running = true;
work_queue(LPWORK, &_work, (worker_t)&SC16IS752::i2ciox_trampoline, this, _i2ciox_interval);
int SC16IS752::reset(void)
warnx("resetting");
return (_write(FCR, CHANA, 0x07) + _write(FCR, CHANB, 0x07));
int
SC16IS752::_read(uint8_t reg, uint8_t chan, uint8_t &value)
int ret = OK;
_msg[0] = ADDR;
_msg[1] = (reg << 3) | (chan << 1);
_msg[2] = ADDR;
/* get value */
ret = transfer(_msg, 3, &value, 1);
if (ret != OK) {
goto fail_read;
return ret;
fail_read:
perf_count(_comms_errors);
DEVICE_LOG("I2C::transfer (read) returned: %d; value: %d", ret, value);
return ret;
int
SC16IS752::_write(uint8_t reg, uint8_t chan, uint8_t value)
int ret = OK;
_msg[0] = ADDR;
_msg[2] = value;
/* send addr and value */
ret = transfer(_msg, 3, nullptr, 0);
if (ret != OK) {
DEVICE_LOG("I2C::transfer (write) returned: %d", ret);
return ret;
void
sc16is752_usage()
warnx("missing command: try 'start', 'test', 'stop', 'info'");
warnx("options:");
warnx(" -b i2cbus (%d)", PX4_I2C_BUS_EXPANSION);
warnx(" -a addr (0x%x)", ADDR);
int
int i2cdevice = -1;
int i2caddr = ADDR; // 7bit
int myoptind = 1;
int ch;
const char *myoptarg = nullptr;
// jump over start/off/etc and look at options first
while ((ch = px4_getopt(argc, argv, "a:b:", &myoptind, &myoptarg)) != EOF) {
switch (ch) {
case 'a':
i2caddr = strtol(myoptarg, NULL, 0);
break;
case 'b':
i2cdevice = strtol(myoptarg, NULL, 0);
break;
default:
sc16is752_usage();
exit(0);
if (myoptind >= argc) {
sc16is752_usage();
exit(0);
const char *verb = argv[myoptind];
int fd;
int ret;
if (!strcmp(verb, "start")) {
if (g_sc16is752 != nullptr) {
errx(1, "already started");
if (i2cdevice == -1) {
// try the external bus first
i2cdevice = PX4_I2C_BUS_EXPANSION;
g_sc16is752 = new SC16IS752(PX4_I2C_BUS_EXPANSION, i2caddr);
if (g_sc16is752 != nullptr && OK != g_sc16is752->init()) {
delete g_sc16is752;
g_sc16is752 = nullptr;
if (g_sc16is752 == nullptr) {
errx(1, "init failed");
g_sc16is752 = new SC16IS752(i2cdevice, i2caddr);
errx(1, "new failed");
if (OK != g_sc16is752->init()) {
delete g_sc16is752;
fd = open(SC16IS752_DEVICE_PATH, 0);
if (fd == -1) {
errx(1, "Unable to open " SC16IS752_DEVICE_PATH);
ret = ioctl(fd, IOX_SET_MODE, (unsigned long)IOX_MODE_ON);
close(fd);
exit(0);
// need the driver past this point
warnx("not started, run sc16is752 start");
exit(1);
if (!strcmp(verb, "info")) {
g_sc16is752->info();
exit(0);
if (!strcmp(verb, "reset")) {
g_sc16is752->reset();
exit(0);
if (!strcmp(verb, "test")) {
if (fd == -1) {
ret = ioctl(fd, IOX_SET_MODE, (unsigned long)IOX_MODE_TEST_OUT);
close(fd);
exit(ret);
if (!strcmp(verb, "stop")) {
if (fd == -1) {
ret = ioctl(fd, IOX_SET_MODE, (unsigned long)IOX_MODE_OFF);
close(fd);
// wait until we're not running any more
for (unsigned i = 0; i < 15; i++) {
if (!g_sc16is752->is_running()) {
break;
usleep(50000);
printf(".");
fflush(stdout);
printf("\n");
fflush(stdout);
delete g_sc16is752;
warnx("stopped, exiting");
exit(0);
} else {
warnx("stop failed.");
exit(1);
sc16is752_usage();
exit(0);
