I’m trying to run a script from a Mathworks Simulink tutorial. I followed all the steps in the example and am struggling to figure out what is going wrong. I select my Hardware Board as PX4 Pixhawk 4 and my CMake config is px4_fmu-v5_multicopter (I tried with px4_fmu-v5_default as well). My output during a run is in the screenshot I added and I attached my rc.txt. I also noticed that the GPS works with the normal PX4 firmware but as soon as I try to launch it with the rc.txt file the GPS LEDs don’t turn on and I can’t connect to QGroundControl. Thanks for any help
rc.txt:
#Copyright 2020 The MathWorks, Inc.
# This is the custom rc.txt which loads px4_simulink_app on start-up
set IOFW "/etc/extras/px4_io-v2_default.bin"
# The following modules are always started by default rCS
# https://github.com/PX4/Firmware/blob/v1.10.1/ROMFS/px4fmu_common/init.d/rcS
# uorb
# sercon
# Set the parameter file if mtd starts successfully.
if mtd start
then
set PARAM_FILE /fs/mtd_params
fi
# Load parameters.
param select $PARAM_FILE
if ! param load
then
param reset
fi
# Start the socket communication send_event handler.
send_event start
# Start the resource load monitor.
load_mon start
# Start system state indicator.
rgbled start
rgbled_ncp5623c start
rgbled_pwm start
if param greater LIGHT_EN_BLINKM 0
then
if blinkm start
then
blinkm systemstate
fi
fi
# Start the tone_alarm driver.
# Needs to be started after the parameters are loaded (for CBRK_BUZZER).
# Note that this will still play the already published startup tone.
tone_alarm start
param compare CBRK_BUZZER 782090
if [ $? != 0 -o $STARTUP_TUNE != 1 ]
then
tune_control play -t $STARTUP_TUNE
fi
if [ -f $IOFW ]
then
if px4io start
then
# Try to safety px4 io so motor outputs don't go crazy.
if ! px4io safety_on
then
# px4io did not respond to the safety command.
px4io stop
touch fail.txt
fi
fi
fi
#Starts GPS driver and Fake a GPS signal (useful for testing)
gps start -d /dev/ttyS0 -s
# board sensors: rc.sensors
set BOARD_RC_SENSORS /etc/init.d/rc.board_sensors
if [ -f $BOARD_RC_SENSORS ]
then
echo "Board sensors: ${BOARD_RC_SENSORS}"
sh $BOARD_RC_SENSORS
fi
unset BOARD_RC_SENSORS
battery_status start
sh ${R}etc/init.d/rc.sensors
# Start UART/Serial device drivers.
# Note: rc.serial is auto-generated from Tools/serial/generate_config.py
sh /etc/init.d/rc.serial
# Start the attitude and position estimator.
ekf2 start
fmu mode_pwm # This is required for AUX PWM channels
usleep 1000
px4io safety_off
usleep 1000
px4_simulink_app start
#exit #23-May-2020
