Cannot build MAVSdk examples
I can build MAVSDK using cmake and Visual studio 2022 but I cannot get the examples to build.
The cmake error is shown below
CMake Warning (dev) at D:/Tools/ProtocolTranslator3/SupportLibraries/SDL/VisualC/pkg-support/cmake/sdl2-config-version.cmake:7 (message):
Could not find SDL_version.h. This script is meant to be placed in the
root of SDL2-devel-2.x.y-VC
manual_control/CMakeLists.txt:14 (find_package)
This warning is for project developers. Use -Wno-dev to suppress it.
CMake Deprecation Warning at D:/Tools/ProtocolTranslator3/SupportLibraries/SDL/VisualC/pkg-support/cmake/sdl2-config.cmake:4 (cmake_minimum_required):
Compatibility with CMake < 3.5 will be removed from a future version of
CMake.
Update the VERSION argument value or use a … suffix to tell
CMake that the project does not need compatibility with older versions.
CMake Error at D:/Tools/ProtocolTranslator3/SupportLibraries/SDL/VisualC/pkg-support/cmake/sdl2-config.cmake:16 (message):
File or directory
D:/Tools/ProtocolTranslator3/SupportLibraries/SDL/VisualC/pkg-support/cmake/…/include
referenced by variable SDL2_INCLUDE_DIR does not exist !
D:/Tools/ProtocolTranslator3/SupportLibraries/SDL/VisualC/pkg-support/cmake/sdl2-config.cmake:46 (set_and_check)
Configuring incomplete, errors occurred
Bruce
