I am running my Dronecode-based program on an ODROID-XU4 board and I would like to test it using an instance of the jMavsim simulator running on my desktop computer.
I noticed that, when I try to connect to an ip address different from localhost (i.e. ./droneManager udp://192.168.0.3:14540), the library reports the following bind error:
[09:52:00|Error] bind error: Cannot assign requested address (udp_connection.cpp:82)
Has anybody experienced the same issue? In accordance with the Droncode’s reference guide it should be possible to connect to a simulator running on another pc.
Thank you!
