Apologies if this topic has already been discussed, I could not find any references touching this subject.
I’m in the process of implementing kernel-/userspace separation, known in NuttX as protected build. This has already been done for fmu-v5 but I’m doing it for a different platform and architecture altogether (RISC-V).
After fixing some minor/trivial build issues, I encountered one major architectural issue, which is the usage of enter_critical_section() / leave_critical_section() from unprivileged mode, which is a big no-no. On RISC-V this causes a full system crash due to illegal instruction (trying to run Machine ISA from userspace). On ARM the macros “sort of” work, because the privileged mode instruction which controls the processor state e.g. global interrupt enable is silently ignored.
According to the ARM documentation:
Use CPS
only from privileged software. It has no effect if used in unprivileged software.
I used the term “sort of”, because interrupts are not masked in places where this is expected, so it can cause nasty race / sync issues which will be impossible to debug without knowing the quoted line from the ARM documentation.
But back to my issue and my solution proposal. I see that e.g. px4::atomic<> uses critical sections with NuttX and the usage of px4::atomic<> is ubiquitous. This means (IMO) the patch has to be made either on px4::atomic or preferably on (px4_)enter-/leave_critical_section. My suggestion is to create a new class “px4::critical” or something, that would act as a common interface for atomic sections in user- and kernelspace. In userspace a mutex/semaphore lock would be used, while in kernelspace the implementation can be inlined to call enter-/leave_critical_section() directly. Two separate source modules would be compiled & archived and the correct one must be selected for user-/kernelspace.
So why did I make this post about it ? My understanding of the px4 architecture (even the basic modules to be honest) is quite limited and I would first like to understand a few things:
- Is px4::atomic used from ISR context ? If not is it expected to be ISR compatible ?
- Does my solution make any sense whatsoever ?
- Have you guys with more experience already considered how this could be fixed ?
Any comments and help on this will be greatly appreciated!
